Results 1 to 7 of 7
Thread: Question About Flat Wyes
    Geologist sjsmithjr's Avatar
    Dec 2005
    Knoxville, Tennessee
    Default Question About Flat Wyes
    At the risk of asking a question that's been asked a hundred times (wye is too general a term to search on), is connecting a horizontal branch line to the main horizontal drain via a flat wye allowed, a bad idea, or both? I have it in my head that it's allowed but can lead to problems down the road.
    Sam
    DIY Senior Member Cal's Avatar
    May 2005
    Northern Virginia
    If you are talking about a "T-wye" YES YOU CAN . If it is a Sanitary tee / or short turn tee no you may not .
    Short turn/sanitary tee should only be used from the horizontal to the vertical . Long turn or t-wye is allowed for either.
    Cal
    Dec 2005
    Thanks Cal. Definately not talking about sani-tees or vent-tees on the horizontal. Speaking of that incorrect fitting usage, the DIY'er that redid the drain lines in the house we recently bought used sani-tees for all horizontal branch connections along with 90s, about half a dozen ferncos, a four inch to three inch transition, no cleanouts, and some of the most creative pipe supports I've ever seen - string, left over fittings, and a tree limb. He was so proud of his work he had the relator point it out to potential buyers as a "plus".
    Thanks again,
    Sam
    DIY Senior Member finnegan's Avatar
    Aug 2005
    CT
    When cutting vents into a horizontal line, they must take off between 45 degrees and vertical.
    Default vents
    That is the ideal, but not always possible in the "real" world.
    Dec 2005
    Default Clarification
    Just to clarify, I was talking about horizontal branch drains connecting to the main horizontal drain using a flat wye. I had it in my head, from somewhere, that these connections worked best if rolled.
    As for vent connections to the horizontal using a wye, if you can't roll it somewhere between vertical and 45, don't you assume that at most a correctly sized pipe will never be more than 1/3 full and work from there?
    Sam
    Default vent
    As a practical matter it really doesn't matter, because by the time the vent has to function, the water in the pipe will be at a minimum.
