Results 16 to 30 of 32
Thread: Confirmation of plumbing layout needed
  1. #16
    I like to work from the top first and then work my down.
    I know I need vents through the roof. I know trap arms can only be so long. I start there.
  2. #17
    DIY Junior Member mahuska's Avatar
    Aug 2013
    iowa
    All great points and I tried two different layouts and I have a drawing of the second because the first would have required that I cut holes through the joist too close to the bottom. This second layout takes a vent from the tub to the wall. The first way took the water to the wall and then over to my vertical access but to keep 1/4 per foot I ended up with only and inch of joist left at the bottom of the hole.
    Name:  plan 4 1.jpg
Size:  99.1 KBName:  plan 4 2.jpg
Size:  40.3 KBName:  plan 4 3.jpg
Size:  65.0 KBName:  plan 4 4.jpg
  3. #18
    How about a simple layout picture looking from the top of the fixtures being used in that room.
  4. #19
    Aug 2013
    iowa
    Name:  plan 4 5.jpg
Size:  55.0 KBName:  plan 4 6.jpg
  5. #20
    Nov 2010
    Maine
    The vent for the shower thar runs horizontal below the floor and over to the wall where it then goes vertical. You can't do that. The horizontal section will fill with waste over time, clog and become useless.
  6. #21
    Aug 2013
    iowa
    I realty appreciate the constructive criticism. I thought about what everyone has said and went back to my basic books and made a new plan. I think this addresses the issues raised. Its a bit weird but I tried to get the vent to exit at vertical. This time I also drew in the toilet DWV. Before the start of all of this the main stack was 4 inch cast iron turned and went horizontally under the toilet so they just put a tee on its back for connecting the toilet. the fitting were very corroded and thin on the bottom especially under the toilet. also it was only 13 inches Center to Center main stack to where the toilet needs to feed into that pipe. I rebuilt it the way it was made before and realized that was not a good idea so i rebuilt it in the only way I thought it could fit and work. But now after listening to the pointer on what not to do which has lead me to what is in the drawing now.
Size:  45.1 KBName:  plan 5.2.jpg
Size:  46.8 KBName:  plan 5.3.jpg
Size:  82.8 KBName:  plan 5.4.jpg
Size:  74.7 KBName:  plan 5.5.jpg
  7. #22
    Aug 2013
    iowa
    And her are two more that detail the toilet and overall
Size:  54.9 KBName:  plan 5.7.jpg
  8. #23
    Nov 2010
    Maine
    The shower vent is still flat.
  9. #24
    Aug 2013
    iowa
    No its not, the shower is minimum you can be, two pipe diameters from weir to vent then the vent goes up to 42 inches above floor level before turning horizontal connect into the roof vent..
  10. #25
    Nov 2010
    Maine
    This is getting too hard to follow. No plumber would install anything you have drawn thus far like that. What is your trap to vent distance on the tub?
  11. #26
    Aug 2013
    iowa
    36 inches for the tub. I don't want to install this crazy thing this way either but I don't see an alternative that satisfies minimum branch arm length, allows vents to exit vertically and allow me fit the floor plan
  12. #27
    Nov 2010
    Maine
    Without being there its real hard to get a handle on things. I'm sure there is a "right way" to do this but again, not being able to actually see the framing and locations makes it difficult. That's why we get the big bucks to do what we do LOL
  13. #28
    Aug 2013
    iowa
    I understand and appreciate those working as professionals and the time and effort is represented by being a licensed plumbing professional.
    Here a little context for where I'm at, I live in a small town(<9600) that is 30 miles away from other city's and an hour from a city over 40,000. Iowa has had building codes for a long time but it was up to the municipality to enforce them and that meant for a long time only larger communities even had officialy worried about inspectors and licensing of professionals. About 2-3 years ago Iowa made a couple of changes, they rolled out regulations the required all tradesmen to be licensed and that trades the generally require knowledge of building codes have to pass the appropriate trade exams. The state took on inspection and enforcement of electrical work if the local city did not have a code enforcement and that is done through the state fire marshal. There was no similar action implemented for plumbing. Our city has no inspection not that that is a good thing. All of the tradesmen I have worked with understand the importance of the codes but without enforcement there is not a feedback loop nor the necessity to continually refine your craft. I worked as a house builder and contractor for many years and have a group of plumbers that I worked with and around and I have a sense of who is good and who is so-so and i have run a couple of arrangement for this particular plan by a couple of them and one fellow though the original way would be OK (one that i have not show to this forum) but after I realize the it formed an S-trap. Another comment from a plumbing professional was "tubs don't need vents, they have one built in". So you might understand the environment a little more but with that said I know a guy who does a lot of commercial work maybe he can help. I was just trying to wrap this up because my wife is get "impatient" with me and I am about three months behind.
  14. #29
    Here is a nice link to Bert Polk's plumbing tips
    Tubs need vents
    The toilet can be vented downstream.
    Sometimes we will drop below the floor joists if needed to run our layout, depending on the framing constrictions we have been left with.
    The link above by an Oregon inspector is one of the best I've seen for explaining how things may be done.
  15. #30
    Nov 2010
    Maine
    Tubs don't need traps because they are self vented? I hope that was just a mis-quote and he ment to say toilets don't need vents because they are a full siphoning fixture. Anyhoo......... I think your best bet would be to find a local plumber that comes recommendd and pay him to do the rough in.
  1. Confirmation on bathroom layout (detailed layout provided)
    By dantheboatman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2013, 12:12 PM
  2. Basement Plumbing Layout
    By jpb123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2012, 03:21 PM
  3. DWV Layout Advice Needed
    By moserro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2010, 06:53 PM
  4. New Construction Plumbing Layout
    By eyeglow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-20-2010, 07:20 AM
  5. Please comment on plumbing layout
    By edwardrroonney in forum Shower & bathtub Forum & Blog
    Last Post: 04-01-2009, 05:42 PM
