Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Confirmation of plumbing layout needed
    DIY Junior Member mahuska's Avatar
    Aug 2013
    iowa
    Default Confirmation of plumbing layout needed
    Hello All
    I have just redone the layout for the third time and i think this one might work. I am using a old laundry shoot to take new pipes to the basement. This is a story and a half and the load bearing wall below is in line under the bathtub and shower space and it carries the toilet and sink waist pipe to the basement (not shown). The shower is a curbless design using Kerdi Line so the joists are cut down and sistered. What do you think?
    Name:  shower tub DWV layout 1.jpg
Size:  91.1 KBName:  shower tub DWV layout 2.jpg
Size:  56.8 KBName:  shower tub DWV layout 3.jpg
Size:  42.2 KBName:  shower tub DWV layout 4.jpg
Size:  93.7 KBName:  shower tub DWV layout 5.jpg
    Nov 2010
    Maine
    Tub vent is flat, no go. Must rise vertical until 6" above flood level rim of the highest fixture served by the branch which is the lav.
    quote; Must rise vertical until 6" above flood level rim of the highest fixture
    That is only half of the requirement. The full requirement is 6" above the flood level of the highest fixture OR 42" above the floor WHICHEVER IS HIGHEST.
    Nov 2010
    Maine
    Ipc only says 6" above highest fixture served.
    Aug 2013
    iowa
    So this can't be a wet vent? Also if this is problem with the tub would it also so be a problem with the shower which is the same design, different shape. Also Iowa adopted UPC 2009
    Well, since the IPC is an "anything goes code", that would explain it. A toilet would only require that it be about 21" above the floor. The good codes assume that a kitchen sink COULD be added at some later date which would require the 42" height, therefore they require it from the beginning.
    Aug 2013
    iowa
    This is a remodel and the second floor walls are not over the downstairs walls. I did not move the walls and the tub is now where a shower was that had no vent at all. The wall with the vents is 2 feet out over the living room. Even if i could go straight down through the load bearing wall directly under the tub the vent has to to go to a wall so this is why i use something like a wet vent concept. I do not see many options here so any ah-ha moments would be greatly appreciated.
    Ah-ha moments occur when we are there and can actually see the entire situation. Why are you using a right hand tub? Is there going to be a wall there that you are not showing?
    Aug 2013
    iowa
    Its a corner tub next to a shower. No other walls are going to be built.
    Name:  shower tub DWV layout 6.jpg
Size:  92.5 KBName:  shower tub DWV layout 7.jpg
    Aug 2013
    iowa
    What if I dumped the 1.5 tub drain into the 2 in with a wye and 60 deg bend so the entry into the 2 was at a 45 down and the 2 inch continued to the wall as is to vent. Would this work or would that just make an "s" trap?
    Aug 2013
    iowa
    It seems like it this system as i have drawn was looked at as a wet vent system then it could work (UPC 908.1) or i could tuck an island sink type vent under the rim of the tub (UPC 909.0)
    Nov 2010
    Maine
    It is in no way a wet vent system. There needs to be a fixture upstream for it to be wet vent. What you have is a flat vent which won't fly
    Aug 2013
    iowa
    So if i delete the vent section going to the tub and use a long sweep or better a combo wye to connect the tub this becomes a branch and put a clean-out on the end of the wye using a 45 or 60 bend to angle it up to the tub service access that would work?
    If I interpret what you said properly, then you would create a 3/4 "S" trap, which is just as bad as a full "S" trap.
    Aug 2013
    iowa
    I might have a solution that that will work avoiding the issues brought up. I with make the changes and post later.
  1. Confirmation on bathroom layout (detailed layout provided)
    By dantheboatman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2013, 12:12 PM
  2. Basement Plumbing Layout
    By jpb123 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2012, 03:21 PM
  3. DWV Layout Advice Needed
    By moserro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2010, 06:53 PM
  4. New Construction Plumbing Layout
    By eyeglow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-20-2010, 07:20 AM
  5. Please comment on plumbing layout
    By edwardrroonney in forum Shower & bathtub Forum & Blog
    Last Post: 04-01-2009, 05:42 PM
