Results 1 to 10 of 10
Thread: Drop Pipe Choice With New Pump
Hybrid View
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    Default Drop Pipe Choice With New Pump
    I'm out of town (of course) and my wife calls saying there is no water. I'll get dad to go over and test and see what we can find out, but I don't have a good feeling.
    Assuming I need a new pump, what do you recommend for drop pipe? 4" pvc casing, 80-120' deep (probably 80'), 1/2 HP pump currently on galvanized pipe. Some sulfur and iron in water. I've seen a couple new wells recently put in with pvc drop pipe and this seems a good way to go. What type of pipe and couplings are best? Thread sealant? How tight? I appreciated any and all advice!
    Also, on the CSV, would I put one in the well or above ground near my pressure tank?
    Thanks,
    Travis
    Wow, haven't been on here in a while and my avatar is a cat!
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Sch 80 pvc drop pipe with sch 120 PVC couplings. We use Rector seal and tighten the pipe & couplings hand tight, but some guys run them up a little with channel lock pliers.
    And NO after thousands of installations over 25 years, we have never seen a string of pipe unscrew.
    Nov 2010
    Maine
    1" PE. With brass or stainless adapters
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    I like polyethylene pipe with brass or stainless steel adapters. We ran pumps as deep as 400 feet on a good grade of 1" polyethylene pipe in Northern Pennsylvania and it worked fine. PVC is OK but always an effort to pull. I'd use an adjustable (not plastic) CSV valve near the tank.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Apr 2012
    ct
    160 lb poly will support the weight of the pump ok, but it is super flexible and the wire will get chafed up big time unless there are plenty of torque arresters installed. Another problem is that when you have to pull poly, it lays on the ground and can pickup all kinds of bacteria and transfer the bacteria to the well.
    Nov 2010
    Maine
    We never use anything around here other than poly unless the well is over 500' or so.
  1. toilet choice with no elevation drop
    By cabman334 in forum Toilet Forum discussions
    Last Post: 09-05-2012, 01:03 PM
  2. Submersible pump choice help
    By Limicolous in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-29-2012, 01:12 PM
  3. 11 yr old drop pipe and wire reusable on 220ft pump swap......?
    By xlr8tion in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-14-2012, 03:08 PM
  4. Assistance needed in residential pump choice!
    By RickNAZ in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-17-2010, 08:25 AM
  5. how to drain the drop pipe
    By rick.a in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-23-2008, 07:31 AM
