Results 1 to 8 of 8
Thread: Question about 1 hole versus 2 hole kitchen faucets
    DIY Junior Member Chuck Roy's Avatar
    Aug 2013
    Pennsylvania
    Default Question about 1 hole versus 2 hole kitchen faucets
    We are getting a new granite counter in the kitchen and are looking at new kitchen faucets.
    The faucet that my wife likes the most (Delta Pilar with Touch2O technology) will require two holes - one for the handle and one for the spout.
    My concern is what happens if we decide to change to a one hole faucet after a few years. What happens to the second hole in the granite?
    If I need to have the granite guys save me some of the left over granite, I need to let them know before they cut and install it.
    Any ideas anyone has would be appreciated.
    Chuck
    It probably isn't a big issue...use the second hole for something like a soap dispenser, a hot water dispenser, or you could cap it.
    As a last resort, most single hole faucets have a "deck plate" which covers extraneous holes.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    The problem is when you trade from a one hole faucet to a two hole faucet and the holes are not centered (which may never happen).
    By the way, when granite installers cut holes in the granite, the round pieces that fall out are pretty much unusable.
    quote; The problem is when you trade from a one hole faucet to a two hole faucet and the holes are not centered (which may never happen)
    Actually, the spout hole, which is the critical one, is ALWAYS properly centered on the sink Supplementary holes, are spaced off it, usually on 4" centers. Some prudent homeowners prefer that the installers drill 3 or 4 holes on 4" centers in case they decide to add soap/lotion dispensers, r/o faucet, hot water dispenser, drain operators, etc. My sink has 6 holes in it and all are being used, (in fact I could have used a seventh one for disposer remote switch).
    Aug 2013
    Pennsylvania
    Default Crisis may be averted
    Wife & I met with the granite people today to look at how the counters will be cut from the slab. After we decided on the layout, I asked them the question about what to do with the second hole if you later switch to a one hole faucet.
    Two items were decided.
    1: I will get all of the leftover granite from the slab. There is not enough left to be sold as remnants so they will just give it to me. If needed sometime in the future, there will be enough to make some sort of plug or cover for the hole.
    2: My wife decided that she can live with the one hole faucets.
    Thanks for everyone who replied. Now, can't wait to get this project completed.
    Chuck
    Well, the faucet isn't ALWAYS centered...on mine, with a D-shaped sink, I've got mine about at the corner of the curve in the D, on the right-hand side. I've got a filtered water faucet centered on the curve, and a soap dispenser on the left-hand corner. Since it's a high spout, pull-out and I'm right-handed, not having to reach across the sink is easier, and I can set a pot on the counter to fill, rather than in the sink, which may or may not have stuff in it! On custom stuff, there is no right or wrong...it's where you want it. Damn the convention - I like my layout better. It also makes future access easier, since there's more room and you don't have to try to see and feel behind the silly sink next to the wall (my base cabinet is moderately large, so there's room on the side).
    But, if you had a "two hole faucet" like the being asked about, the spout hole would STILL be where you have it and the other one would be to one side or the other of it. THAT hole is the one a single handle faucet, like yours, would then use if it were changed and the other hole would be utilized for something else.
  1. Need a reliable three hole kitchen faucet
    By E. Williams in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2013, 06:39 AM
  2. Kitchen Sink Hole Repair Help.
    By ckranez in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2011, 05:01 PM
  3. Pin Hole Leaks in Kinston Brass Faucets
    By tetonniki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2009, 01:40 PM
  4. size hole for single hole faucet
    By bobbieK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 01:31 PM
  5. drilling hole in SS kitchen sink
    By ddurand in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2007, 07:26 AM
