Results 1 to 7 of 7
Thread: Pump starter relay
    DIY Junior Member fendall's Avatar
    Aug 2013
    Atlanta
    Default Pump starter relay
    Just replaced 1.5hp flotec pump with 2.0 hp, but now can't get relay to start pump. It clicks, and my meter shows I'm getting 120 v at the pump, but pump won't come on. Checked my 20 year old starter relay and noticed it was only rated for 1 hp at 120v ( although it's worked great with the 1.5 hp pump). I'm guessing I need a new relay rated for 2 hp at 120v, but don't want to spend the money if this isn't the most probable problem. Any suggestions? Pump comes on when I plug extension cord direct to it. Thanks
    Jan 2008
    Virginia Beach, VA
    Not enough information to make an accurate diagnosis but I suspect that your 1.5 and 2 hp pump needs 220 volts to work best. Is this a jet or submersible pump?
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Mar 2011
    Houston, TX
    2 HP pump should be wired for 240, not 120.
    Aug 2013
    Atlanta
    Thanks guys, but pump is rated for 120v
    Mar 2011
    Houston, TX
    Quote Originally Posted by fendall View Post
    What model is it ?
    When you say Pump starter relay, are you talking about the pressure switch ?
    Nov 2010
    Maine
    If you have 120 going to the pump and the pump won't run then you either have no connection at the pump or the pump is bad out of the box. Either way, the pump need to come out again
    Mar 2011
    Houston, TX
    If it is a Jet pump, that is what I was thinking it was, Someone may have forgot to set the voltage. But it was said that it works on a extension cord. ??
    A 2 HP pump should be on 240, That is what I would use.
    Not that 120 wont work with bigger wire, 240 will work more better. Some 2 HP pumps will not even have a 120V setting. (The Good ones don't, or they are not really 2 HP, People like big numbers.)
    I also would not use a 1 HP control for a 2 HP pump, That is asking for trouble.
    More details would be nice.
    PS. I like your tag line, actually rocket science requires many licenses, Thanks to ISO and OSHA.
  1. Pump starter turns off after 9 seconds
    By robertpatterson in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2009, 05:56 PM
  2. Start Pump Relay
    By he8833 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-14-2009, 12:23 PM
  3. Pump Start Relay (I think)
    By he8833 in forum Irrigation / Sprinkler Forum
    Last Post: 08-13-2009, 12:59 PM
  4. Pump Start Relay / timer
    By dmathieu in forum Irrigation / Sprinkler Forum
    Last Post: 06-26-2008, 08:36 PM
  5. Pump Control Relay
    By garcanser in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-15-2007, 08:30 PM
