Thread: Help! Replacing bath tub
    DIY Junior Member Tominct81464's Avatar
    Aug 2013
    Default Help! Replacing bath tub
    Hi,
    I have replaced an old tub with a new one, but it didn't fit perfectly in the surround, something not square, I read the instructions b/c I was concerned about where the wall would sit....the directions said
    To place fur strips on the beams....so I did, but. Know that the tub wall will extend out 1/4 inch more than the regular drywall!? What to do???
    You have a basic framing problem, but without actually seeing it there is no way to answer your question. Furring strips are usually NOT the solution if you have to match to an existing surface, however.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Can you up load photos?
    Almost anytime you remodel you have to compensate for out-of-square and/or non level surfaces. There are no pat answers that will solve every problem you encounter, you have to be creative.
  1. replacing bath fan
    By arrow in forum Remodel Forum & Blog
    Last Post: 08-01-2012, 06:57 AM
  2. replacing Moen bath/shower trim
    By CentralTXPreacher in forum Shower & bathtub Forum & Blog
    Last Post: 09-14-2010, 01:46 PM
  3. Replacing bath tub spout and cut nub too short????
    By idreos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2007, 06:59 AM
  4. from bath remodel to replacing whole house plumbing
    By gibbie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2007, 08:23 PM
  5. replacing bath/shower fixtures
    By vleespet in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-09-2006, 07:40 AM
