Thread: wellpump noise throughout the house
    DIY Junior Member d_butka's Avatar
    Oct 2004
    Default wellpump noise throughout the house
    My house is on a slab. My well pump is not noisier than most, but I would like to isolate the noise from the rest of the house.
    I assume a flexible hose right after the pump/ tank would do it. Would appreciate suggestions.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Convert to a submersible, you will never hear the pump again.
    Mar 2011
    Houston, TX
    I like to hear my pump when it runs, You know when you have problems.
    It may be time to find out why it runs long enough to bother you.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    My well is about 130 ft from the house. I have a submersible pump down in the well and I can hear it when it comes on. The sound travels through the water I guess because the pipe is PVC from the well to the house and then changes to copper. I mostly hear it when I am in bed with my ear against the bed. Like Don mentioned I know I have a leaky toilet flapper or the wife left the spigot dripping when I hear it in the middle of the night.
  1. Humming noise in natural gas pipes in the house
    By AJ Soprano in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2011, 08:31 AM
  2. Main line leak causing banging noise in house? How to locate?
    By JimLS in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2010, 05:41 AM
  3. House makes burping noise
    By Eric E in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2006, 10:15 AM
  4. Water Draining Noise Thru The House
    By Sailor Sam in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2004, 06:18 AM
  5. Water Draining Noise Thru The House
    Last Post: 10-30-2004, 09:04 PM
