Results 1 to 7 of 7
Thread: How to avoid S-trap with a pedestal sink and floor drain?
    DIY Junior Member jmcr's Avatar
    Aug 2013
    new york
    Default How to avoid S-trap with a pedestal sink and floor drain?
    Hey guys,
    I'm a bit of a novice trying to install a pedestal sink in our bathroom which has a floor drain instead of a wall drain. The drain is on the floor about an inch away from the wall, between the two water supply lines which also come up from the floor.
    I've read that S-traps are against code but it seems like the only way to connect a pedestal sink to this floor drain that's located almost directly under the sink.
    I think using a P-trap with the two diameter arm length would force the sink to be very far off the wall when its designed to go flush.
    Any advice on what to do?
    Nov 2010
    Maine
    So you are going to get guys telling you to use a San-tee with an AAV on the top of it but lets be realistic. It's going to look like crap which defeats the purpose of the pedestal sink so, here's some advice from someone that normally would never say such a thing but....get yourself a nice matching metal S trap and a matching escutcheon and install a illegal trap.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Tom Sawyer...you can't be serious!
    Nov 2010
    Maine
    So maybe the s trap pulls occasionally although its not too likely. Besides which, if he's doing a renovation and has not altered the existing plumbing, it is considered a repair and he doesn't have to change it.
    Aug 2013
    new york
    Thanks for the reply! That's interesting about not having to change it. It is a renovation and the original plumbing wasn't changed so maybe the S trap is the best option.
    I finally got a picture of what it looks like:
    The pedestal is in the right position for the sink to be flush with the wall. I have just the J bend of a P trap kit attached to the sink tail and a pipe(thats too short) coming out of the drain to show the distances.
    Even if I cut the P trap arm to well under the 2x pipe diameter length for code it would still never fit.
    Would a double offset work to push the drain back to the wall and maybe the P trap arm could fit then? Something other than a double offset?
    How would you guys approach this in a way that doesn't look too crazy behind the pedestal?
    Nov 2010
    Maine
    You don't have the room for a p trap and the existing drail lines up perfect for a S trap so quit worrying and go with the S trap.
  1. Pedestal sink install thru floor?
    By Brambly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2012, 04:04 PM
  2. Pedestal sink in new home- supply lines through floor?
    By HC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-16-2009, 07:41 AM
  3. Hide trap below floor for Pedestal sink
    By gorman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2008, 03:58 PM
  4. Plumbing pedestal sink under floor
    By llt01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-20-2006, 01:39 PM
  5. drain on old pedestal sink
    By jboatman333 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2004, 05:37 AM
