Results 1 to 7 of 7
Thread: Cistern well overfill question
    DIY Junior Member andrmegn's Avatar
    Aug 2013
    NE Iowa
    Default Cistern well overfill question
    We live in an older Victorian home with a cistern well for water supply. We don't know anything about it but have noticed the well is completely full lately. Is this anything we should be concerned about? It doesn't appear to be affecting our water pressure.
    Andrea
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Have the water tested for bacteria regularly.
    Feb 2011
    NW Ontario, Canada
    The cistern may be spring fed.
    Moderator valveman's Avatar
    Mar 2006
    If there is a well pump feeding the cistern, the float switch maybe stuck, and the cistern it full to the overflow pipe.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Where does the water come from? The cisterns I've worked with in the past were tanks under the house that were filled from roof gutters. If it has rained a lot and you have that type of cistern, that might be why.
    Aug 2013
    NE Iowa
    There is a well pump in the base of the cistern. When I first moved here, I never noticed water in the cistern. I have a sump pump hooked up but the water level doesn't ever seem to go down. Where would I find the float switch?
    Mar 2006
    Your system should look something like this.
  1. Install new line to cistern wall, worried about loose dirt flow back into cistern
    By abeljda in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-15-2010, 04:55 PM
  2. help...old cistern
    By skinsthegolfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2009, 09:25 PM
  3. Irrigation pump and cistern question
    By aquaholic in forum Irrigation / Sprinkler Forum
    Last Post: 02-12-2009, 06:58 PM
  4. cannot get water out of cistern
    By Selgea in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-31-2008, 04:52 PM
  5. Cistern or Well?
    By NewOldHome in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2007, 09:46 AM
