Thread: Kohler tub drain assembly
    DIY Junior Member Kerri's Avatar
    Aug 2013
    california
    Default Kohler tub drain assembly
    I converted my Kohler tub to a walk in shower by having the Tubcut people modify it (worked great by the way.) Now I never need to close the tub stopper because I never want the tub to fill with water.
    The tub drain was very slow and so I took the overflow thing apart and pulled out the stopper control arm and found that the spring in the stopper assembly was full of hair.
    Do I need that spring in there? The tub is draining fine now, and as I said, I never want the tub stopper closed. I did not put the spring/arm back because it will just get clogged again and I don't need the stopper to close.
    The tub drains to a greywater system, not to septic or sewer pipes.
    What could go wrong with that spring removed?
    Kerri
    You only need the spring if you intend to use the stopper.
    Aug 2013
    california
    That's great news. Thanks so much for your excellent website.
  1. Trouble getting tee assembly off of a Kohler Revival
    By FredMertz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-13-2013, 04:54 PM
  2. New Tub & Drain Assembly
    By billrea99 in forum Shower & bathtub Forum & Blog
    Last Post: 03-28-2010, 11:02 AM
  3. Lav Drain Assembly Issue
    By Valleykat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-14-2009, 06:55 PM
  4. Shower Drain Pipe too Short for Drain Assembly
    By ilovedogs in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2009, 08:19 AM
  5. Drain Assembly Connection
    By txlandlord in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-27-2006, 06:16 AM
