My shallow well pump is LOUD - house is only 600 square feet, but you can hear it. Definitely on the way out. What are some good replacement models? burcam any good? I've read Goulds is the best but can't find them locally in Ottawa.
There isn’t a nickels worth of difference between most pumps these days. It is the little “tankless”, pressure on/flow off controller that is the problem. These things are marketed under several different names, and every few years they change the name again. I started seeing them many years ago as Masscontrols or Presscontrols. Now many pump companies sell a version of that device. If you want something that doesn’t last, is hard on pumps, and needs to be replaced regularly, then get what all the pump companies are pushing. That would either be the Burcam, “Masscontrol”, or a variable speed (VFD) system. If you want a pump system that will last, which is why pump manufacturers don’t like them, use a Cycle Stop Valve or a Pside-Kick kit instead of the Burcam thing.
Anyone familiar with bur-cam? comparable price wise, Canadian company. Stainless steel.
Stainless steel ? For a shallow well pump ? What part is stainless, the washers and bolts ?
What is the model ? Do you have a link to it ?
Is your pump in the well ?
Pump is not in the well no.
http://www.burcam.com/en/products?view=details&mainsection_id=100§ion_id=20&cat_id=230&sku=503321
Will have to be something along those lines.
Amazon.com. Goulds j5s from $299.00
Did a bit of quick reading - sounds very interesting. The CSV is expensive but I'm intriqued. However, I'll still need a pump of some sorts, correct? Need to get that water out of my well somehow.
If the warranty is good and the price is right I suppose I would probably go with it.
