Delta R10000 installation...leave plastic screen in during soldering??
old_man
maryland
Folks,
Delta R10000 installation instructions indicate to leave plastic screen in place during soldering, but to "avoid high temperatures" since it may damage screen!?
Any idea why they want you to leave screen on, then have to worry about using too much heat?
I see photos online of installs that show it removed, presumably to facilitate soldering, which seems like the sensible thing to do (assuming it actually comes off, maybe it doesn't, I have not tried).
Themp
Active Member
Raleigh, North Carolina
I had the same question a while back replacing my shower valve with a R10000. I removed it during the soldering phase, just did not want to take any chance. Then when I was done I never put it back as I flushed the lines with no valve in place. Someone commented that in a normal whole house plumbing job it is to catch all crud in the lines when flushed and before the valve is in place. Then there is the plug that you have to use if you do not install the valve right away to prevent crossover, that gets in the way of the screen, so again I did not use the screen again because of this.
