Thread: Bathroom sink drain slope / trap questions
    DIY Junior Member Tim Miller's Avatar
    Aug 2013
    Virginia
    Default Bathroom sink drain slope / trap questions
    Hello all,
    I'm finishing up a full bathroom renovation. It has been a seven-day-per-week job!
    I have a new bathroom vanity, and vessel sink. It sits much higher than the previous sink, and there is a bottom drawer in the vanity that hugs the sanitary tee.
    I believe that the `P` trap should be located in plane, more or less, with the sanitary connection at the wall. Unfortunately for me, this would require eliminating or modifying my bottom vanity drawer, which I would obviously rather not do.
    I would prefer to install the trap a little higher up, maybe even right at the sink drain, and make up piping as needed to the sanitary tee. Although this could result in creating a `S` trap, more or less. Or at the very least, a rather steep section of pipe between the trap and the sanitary tee.
    Any ideas on how to accomplish this without having to mess with that bottom drawer?
    I understand that S traps are no longer allowed by code in most cases, although in my brief amount of searching this morning, I have not seen too many horror stories about them. Just a theoretical tendency to jettison the water in the trap from time to time?
    Thanks in advance,
    -Tim
    Electrician Chris B.'s Avatar
    Feb 2013
    Toronto, Ontario
    There is an alternative - open the wall.
    Jan 2008
    Yep, you need to raise the sanitary tee inside the wall. If the weir of the trap is above the vent connection it will siphon the trap.
    Or............if you do raise the p-trap, you will then need to add an AAV to break the syphon when it drains.
    If I can get to those before the cabinet is installed, I like to cut into the wall and raise the santee.
    The other option, which I have done too, is notch the drawer.
  1. Connecting smaller bathroom sink drain to a large P-trap?
    By Bratan in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2013, 05:58 AM
  2. Trying to connect drain tailpipe to the trap in a bathroom sink.
    By slinky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-22-2011, 02:19 PM
  3. Sink drain with insufficient slope
    By keigwin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-03-2009, 06:46 AM
  4. Bathroom sink p trap or t trap
    By ksdad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2007, 06:36 AM
  5. bathroom sink drain pipe and p-trap don't meet
    By rexballinger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2005, 02:17 PM
