Thread: Installing Toto Carlyle II - water supply
    DIY Junior Member Poschspice's Avatar
    Aug 2013
    Portland
    Default Installing Toto Carlyle II - water supply
    I have 7" from center of toilet rough in to center of water supply but it's only about 3" off the floor. Current shut off valve is standard cheaply type so it is wider that the supply. Will this be sufficient for clearance of the skirted bowl or should I have the supply line moved over and up?
    I have read both 6" and 7" from center will work but manual recommends 8" out and 6" up.
    Apr 2012
    New York, NY
    Terry has previously posted that the Carlyle II needs 6" center-to-center for the shutoff valve if it's on the wall. Doesn't matter how high off the floor it is for these purposes. If the handle is too big to turn, replace the stop with quarter-turn ball valve with a small-diameter handle, like on these angle stops. http://www.dahlvalve.com/PDF/Skirted..._Brchre_US.pdf Replacing the stop is normally a trivial job. Also note that those Dahl stops are ideal in the case (unlike yours) where you don't have enough distance from the centerline -- no need to relocate the water supply, just use a stop with a 90-degree turn built-in.
    Aug 2013
    Portland
    Thank you for clarification on this.
    Aside for a better fit, these valves are far better than the old kind. Toilet supply valves should always be fully open, so no need to have one that requires 6 or 8 turns. Quick and easy to go from on to off, off to on.
  1. installing toto carlyle, need help!!!
    By Toto trouble in forum Toilet Forum discussions
    Last Post: 09-26-2010, 02:06 PM
  2. Replies: 6
    Last Post: 05-06-2010, 03:21 PM
  3. Toilet water supply coming up from floor--can Carlyle fit?
    By Bosun in forum Toilet Forum discussions
    Last Post: 01-25-2010, 10:39 AM
  4. Carlyle water supply
    By Tom Banyon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2009, 09:48 AM
  5. Questions - Carlyle vs Carolina? Water Supply? Sanagloss sticker?
    By idesign123 in forum Toilet Forum discussions
    Last Post: 11-16-2008, 09:32 PM
