Richrc1131
I have a ceiling light that has a loose connection between two of the segments. This is one of those low voltage lights.
What happens is that the light randomly cuts off. If I squeeze that connection point, the light will stay on.
The connecting area has a small metal clip on the top and one on the bottom (with a single plastic cover) that bridge the gap. They seem to fit snug but I guess not snug enough to keep the connection. When I squeeze the sides of the plastic cover, it comes on.
There is a screw in the plastic peice that appears to be for tension, but doesn't fix the problem.
Is there an inconspicuous and safe way to connect these two segments?
