Results 1 to 7 of 7
Thread: low voltage light question
    DIY Member richrc1131's Avatar
    Apr 2008
    Central Connecticut
    Default low voltage light question
    I have a ceiling light that has a loose connection between two of the segments. This is one of those low voltage lights.
    What happens is that the light randomly cuts off. If I squeeze that connection point, the light will stay on.
    The connecting area has a small metal clip on the top and one on the bottom (with a single plastic cover) that bridge the gap. They seem to fit snug but I guess not snug enough to keep the connection. When I squeeze the sides of the plastic cover, it comes on.
    There is a screw in the plastic peice that appears to be for tension, but doesn't fix the problem.
    Is there an inconspicuous and safe way to connect these two segments?
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    Those things are known for failing like you describe. Not much to do but replace it.
    Apr 2008
    Central Connecticut
    Default Found the problem with the light fixture
    I discovered the problem. This device is made up of several segments. Each segment needs to be in physical contact (end to end) with the other. They are loosely joined together by what looks like a 3 sided folder peice of metal and a plastic surround which has an adjustment screw on it. This adjustment screw doesn't appear to do much.
    What happens is the two segments appear to work their way away from each other and have to be moved back into place.
    I've included a picture (best I coud do) of the connection point.
    How can I secure these two segments together without making it look too obvious.?
    Jun 2007
    North Carolina
    Buy a new light
    Mar 2011
    Houston, TX
    Buy a new light
    That would be a great Idea.
    It sounds like the Track was not installed properly.
    Too much stuff like this is made in China...now, some of it may be designed here, but if they don't hold them fully accountable on production and QA/QC, what you end up with is crap. They can make some great stuff, but often, it's not! Depends on who designed it and is watching over the process. Garbage in, garbage out. Good stuff tends to actually cost a bit.
    Mar 2011
    Houston, TX
    That is what I was thinking.
    Could probably take it back to WM and get a refund.
  1. Flickering lights on circuit with low voltage and line voltage bulbs
    By davidwie in forum Electrical Forum discussion & Blog
    Last Post: 04-18-2011, 07:34 AM
  2. Running low voltage in high voltage boxes
    By Ian Gills in forum Electrical Forum discussion & Blog
    Last Post: 08-22-2009, 07:27 PM
  3. voltage question
    By djcd34 in forum Electrical Forum discussion & Blog
    Last Post: 07-17-2009, 09:43 AM
  4. Low voltage light flicker problem
    By thebeave in forum Electrical Forum discussion & Blog
    Last Post: 06-17-2009, 07:05 PM
  5. Lights flicker and Voltage Drop Question
    By Pip in forum Electrical Forum discussion & Blog
    Last Post: 12-18-2008, 06:25 PM
