Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: We're back
    Feb 2011
    NW Ontario, Canada
    Default We're back
    Glad to see the forum is back up. Did you run out of disk space?
    Mar 2011
    Houston, TX
    I was getting a Database Error right before it went off line.
    Then Gateway Timeout and Bad Gateway.
    Looks to be working now.
    I had them reboot this morning.
    Feb 2011
    NW Ontario, Canada
    I think the board is still having issues. It has gotten slow lately and the "leave this page" prompt is back.
    Feb 2011
    NW Ontario, Canada
    I'm still seeing "leave this page" prompts.
    Mar 2011
    Houston, TX
    I think that is a routing problem.
    Did Terry change providers lately ?
    Looks like the website IP routing has changed.
    Terry's son Taylor Love's Avatar
    Sep 2007
    Bothell WA
    Hello,
    At the moment we are only using 15% of our total storage capacity, so there shouldn't be any danger of running out of storage space.
    Going to be looking into fine tuning the server to improve speed and efficiency tonight, so there might be unavailability between 11pm and 5am PST tonight.
    In a way, yes. The routing change was because of a server hardware upgrade intended to make the site run quicker. This is a different server from before. I suspect the file system's block size on the new server is lower than the one used on the previous server. That might be what is causing the current bottleneck.
    Moderator valveman's Avatar
    Mar 2006
    Seems to be working better this morning so far. Thanks!
    Feb 2011
    NW Ontario, Canada
    still having performance issues here.
    Mar 2011
    Houston, TX
    Seems to be working fine here.
    You may want to try "Tracert Terrylove.com" in a CMD window and see where the problem is.
    The Forum server is a bit slow to respond, but it does not even come close to timing out.
    Mar 2011
    Houston, TX
    Nice work Terry.
    I guess the upgrade worked.
    Have fun everyone.
    Feb 2011
    NW Ontario, Canada
    I got the gateway error once today.
    Mar 2011
    Houston, TX
    I did also last night.
    I think Terry's IT department may be working in it.
    Seems to be working fine for me now.
    We have a bad drive on the RAID that we will be having replaced.
    Mar 2011
    Houston, TX
    Sounds like time for a few user donations.
    A site like this does not come free, for Terry Love.
    Keep up the good work. You need a Donate Button.
    Users Please step up to the plate, too support this great forum.
  1. DWV Piping Dilemma from Adding wall-mounted toilet on one side of back to back setup
    By DIY_Steve in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2013, 09:19 PM
  2. wall mounted Kohler & Toto Aquia back to back
    By Chaosherder in forum Toilet Forum discussions
    Last Post: 10-21-2012, 08:09 PM
  3. Can one toilet carrier hold back to back wall hung toilets
    Last Post: 06-20-2012, 11:17 AM
  4. Recommendation for toilet in a (sort of) back-to-back configuration
    By jadziedzic in forum Toilet Forum discussions
    Last Post: 07-06-2010, 06:25 AM
  5. Adding bathroom back to back with existing - share 3 inch branch?
    By mturse in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-04-2008, 07:25 AM
