Results 1 to 10 of 10
Thread: Water well Pressure tank inside house
    DIY Junior Member vwmartinez's Avatar
    Aug 2013
    Pearland Texas
    Default Water well Pressure tank inside house
    I am about to have a water well installed. It is a 1-1/2hp submersible that will be 350' deep and located about 50' from the house. It will include a 120 gallon galvanized pressure tank but I am wanting to have the tank installed inside the house. The tank will be located in a closet next to the kitchen and living room, do these tanks make much sound filling with water that would make me regret installing it indoors in a location like this?
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    I would be more concerned with condensation.
    If the system is set up with air release valve there will be a slight hissing but that's about it.
    Moderator valveman's Avatar
    Mar 2006
    You also might hear a little air gurgling each time the pump starts. And if you are using the old style air over water tank because you have Sulfur or something stinky in the water, the air volume control might be letting the "stink" in the house.
    Aug 2013
    Pearland Texas
    Would the tank have much condensation if it was in a air conditioned space? I guess I could have it installed on a water heater over flow catch pan that drains outside.
    Aug 2013
    Pearland Texas
    I did not think about the air release valve letting sulfur smelling air out inside the house. I will question them about that. Thanks
    Apr 2012
    ct
    About the condensation, it would depend on the temp of the ground water where you are. Here in Ct the water is about 53 degrees.
    I forgot about the possible surfer smell.
    Jan 2008
    Virginia Beach, VA
    Ask Valveman but I think I would recommend a Pside-kick.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Mar 2006
    Quote Originally Posted by Porky View Post
    No. Not unless you use a Sulfur Eliminator or some other way of getting rid of the sulfur smell without using the big air over water tank.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Put the tank in the garage, not the house. It will sweat in the summer time. Our GW temp is 67-72* here in SE Texas. Also have you considered locating the tank outside?
    Aug 2013
    Pearland Texas
    I am going to go ahead and place the pressure tank outside the house but about 40 feet from the well.
  1. Aerobic septic tank smells inside house
    By Lightwave in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2011, 02:50 PM
  2. High water pressure outside; low inside house
    By cepperson3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2010, 11:11 AM
  3. Bleaching inside Hot Water Tank
    By foxhome01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2008, 05:46 PM
  4. No water in house, but pressure in tank.
    By lwerdmann in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2007, 11:08 AM
  5. cleaning the inside of a hot water tank
    By Alexdc99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2005, 10:26 AM
