Results 1 to 6 of 6
Thread: Need help desperate!..ONE BATH HOME!!
    DIY Member theelviscerator's Avatar
    Oct 2007
    Elkhart, IN
    Default Need help desperate!..ONE BATH HOME!!
    2 valve shower no mixer I think I need to remove a threaded cap here, but the whole thing wants to spin out behind the wall, but not come all the way out either.
    How to fix this kind? what is it?
    Any help is appreciated...Name:  001.jpg
    these are quarter turn valves also.
    valves are leaking is main issue.
    The world is a grindstone, whether it wears you down, or polishes you up, is up to you.
    Oct 2007
    Elkhart, IN
    Kind of disappointed nobody here knows enough to tell me what this is.
    Seems its either a delta or a tuscany brand shower valve.
    the reason it wouldnt come out is the genius who installed it only drilled the holes large enough for the small end of the cap to come through, once I enlarged the holes it just came out the front.
    ******* had a tuscany brand cartridge kit with valve seats and and the long extensions that worked once I ground down the end closest to the valve handle so it went to the end of the retaining cap.
    (the shinier part where my water pump pliers had scraped it).
    No leaks now.
    Hope this helps someone else out in the future. When installing a new shower valve make sure you can remove all components for replacement later.
    This awful shower enclosure is the last thing in this house I havent demo'd and replace yet, mainly because its ONLY a 1 bath home. But its coming up now. SOON.
    Your picture is no help for determining the manufacturer which is why nobody answered your question. But, it is NOT a Delta valve, and if it were, the size of the holes in the wall would be irrelevant. Show us the handles and a picture of a stem which has not been "mutilated".
    Oct 2007
    Elkhart, IN
    It was plenty of help somewhere else, so must be you hj.
    and its fixed 100% no leaks, no drips. Must not be too mutilated.
    So in the future is there is a problem with the pic, please mention it.
    With ZERO responses its kind of hard to assume the pic is no good.
    Jul 2009
    North Vancouver, BC
    So are you going to let us know what brand yours was or just complain about the free service? JW
    This is your chance to polish things up.
    Your answer about the brand can help others in the future.
  1. Tankless water heater selection for 3 bath home
    By vestaviascott in forum Tankless Water Heater Forum
    Last Post: 07-31-2012, 02:30 PM
  2. Home Run Plumbing Design For New Home with far away bath
    By brianslink in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-16-2011, 07:25 AM
  3. Desperate need of help!
    By jasonpbutler1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2009, 07:11 AM
  4. 1/2 bath to 3/4 bath home improvement
    By JONES-SMITH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2008, 03:07 PM
  5. Installing an overflow drain in a new bath tub in a manufactured home
    By dmachamer in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2006, 04:28 PM
