Results 1 to 6 of 6
Thread: Advice on new shower faucet/valve kit
    DIY Junior Member eric price's Avatar
    Aug 2013
    Northern California
    Default Advice on new shower faucet/valve kit
    Doing a full shower/tub remodel, looking for advice on new a faucet/valve/spout hardware kit. Looking at a Grohe 35 018 Europlus kit but not set on it... seen mixed reviews. Contributors here seem to speak well of Delta, but I'm open and have a flexible budget. Any advice on good deals on good products (ideally not the plastic crap I saw at Home Depot)?
    *edit- also now looking at Delta T17485 Grail Monitor 17 as a possibility.
    *edit #2- pressure from wife and bought the Delta. I'll revisit this and review when its installed.
    In the Sacramento, CA area and will be hiring a professional for the plumbing .
    Thanks in advance!
    Monitor 17 was a good idea. Listening to the wife and buying her choice of the Grail may be an even better decision, (couches can be uncomfortable to sleep on).
    FWIW, I've had good luck with both Grohe and Delta...the Delta parts may be easier to get (depends on where you live, in some places, it's a wash - they're both quickly available).
    DIY Junior Member old_man's Avatar
    Apr 2010
    maryland
    Quote Originally Posted by eric price View Post
    ...Any advice on good deals on good products (ideally not the plastic crap I saw at Home Depot)?
    I'm in the process of installing R10000 as well. I have read online discussions regarding big box stores selling lesser quality valves with plastic parts. Decided to not take a chance and went to local plumbing supply outfit and purchased the T17430 trim kit.
    Brought it home, opened it up, and virtually everything in the box is plastic. Plastic spout, plastic shower head, plastic escutcheon. All of the visible components of the valve appear to be plastic with the exception of a round metal plate with 2 holes in it.
    Even stranger, Delta specsheet indicates that T17430 is not an actual product part number but a product "series". It shows that it can come with a metallic spout (RP17454), or a non-metallic spout (RP17453). Yet nothing on the box indicates which "options" are actually in the box, the only nomenclature is T17430.
    Anyone have any experience with this? Does anyone know where I can obtain the "good" Delta trims? (I'm in Maryland).
    As to the guts where water touches things, the regulations are moving towards prohibiting anything that might contain any lead, so to comply, places are using more and more plastic in them. It sounds like you bought your stuff at a big box store...most plumbing supply stores sell the pieces individually, not bundled in a set. So, you're stuck with what's in the bundle. BUy it either on-line or at a local plumbing supply store and the rough-in comes in one box, the trim and cartridge in another, and the tub spout in another, and, if you want a shower head, you pick that out separately as well. From a practical viewpoint, if you don't use abrasive cleaners, the plastic stuff will last a very long time and look good.
    Apr 2010
    maryland
    ... It sounds like you bought your stuff at a big box store...most plumbing supply stores sell the pieces individually, not bundled in a set. So, you're stuck with what's in the bundle. BUy it either on-line or at a local plumbing supply store and the rough-in comes in one box, the trim and cartridge in another, and the tub spout in another, and, if you want a shower head, you pick that out separately as well. From a practical viewpoint, if you don't use abrasive cleaners, the plastic stuff will last a very long time and look good.
    As I said, I went out of my way to avoid big box store, I made this purchase at my local plumbing supply store. The R10000 rough-in was separate, the rest of trim including spout and shower head were part of T17430.
  1. Advice needed about purchasing Speakman faucet/valve
    By Gerri in forum Shower & bathtub Forum & Blog
    Last Post: 08-19-2012, 12:26 AM
  2. Shower Mixing Valve Replacement Advice
    By lkstaack in forum Shower & bathtub Forum & Blog
    Last Post: 05-24-2012, 03:34 PM
  3. Advice please on Delta single hande shower faucet
    By babifav in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-15-2010, 12:56 PM
  4. Need advice on shower & tub faucet fixture update
    By 408George in forum Shower & bathtub Forum & Blog
    Last Post: 02-05-2009, 12:33 AM
  5. Need Advice on Shower Faucet
    By mm530 in forum Shower & bathtub Forum & Blog
    Last Post: 11-12-2008, 10:32 AM
