Page 4 of 4 FirstFirst 1234
Results 46 to 50 of 50
Thread: old house with oil/steam heat - help
  1. #46
    DIY Member
    May 2012
    Brooklyn, New York, United States
    Quote Originally Posted by BadgerBoilerMN View Post
    I have a signed copy, thank you..
    Maybe now is the time to read this book?
  2. #47
    DIY Member
    May 2012
    Quote Originally Posted by Dana View Post
    "Promoting" a practice is a very very distant cry from "mandating". When the math proves that it's not necessary, it's simply not necessary. Presuming that P/S is the only way to "do it right" is for folks who can't or won't do the math (which is apparently the vast majority of boiler installers.)
    Since P/S piping can limit the damage from a host of design errors from the folks who can't/don't do math it's in the manufacturer's interest to promote the practice, but that doesn't mean it's always the right thing to do.
    Are you even reading my posts?
  3. #48
    DIY Member
    May 2012
    Two words " VFD pumps"
    Sure VFD or at least bypass pressure differential. VFD will decrease flow trough system and boiler without separation when load will drop. Differential pressure by pass will keep same max flow trough the boiler even system flow might be very low, if there is no separation when load will drop. But there is certain flow and delta t requirements for the proper boiler operation. How can you meet those criteria in those conditions, if there is no separation?
  4. #49
    In the trades Dana's Avatar
    Jan 2009
    Quote Originally Posted by gennady View Post
    Sure. Are you even reading BadgerBoilerMN's posts?
  5. #50
    DIY Junior Member izhadano's Avatar
    Sep 2013
    MA
    I had a chance to install steam boiler with modifications of steam heating system and condensing boiler on 2 identical brownstones within couple blocks from each other. The gas bills were within 20 dollars difference on winter month. Taking into account electrical charges to drive 2 pumps I would say it was very close call. Good steam system can compete with hot water system. And definitely not worth to convert steam system to hot water. On steam systems oil to gas conversions our average results are 70-75% fuel reduction, depending on how screwed up steam system was.
    Gennady,
    would you please provide more information on changes made to the buildings (insulation, windows, etc.) when modification were made to steam heating system and when steam boiler was replaced by condensing boiler. I'm very interested in your observations. Hot water condensing boilers has an impressive energetic efficiency (based on 1 Law of Thermodynamics) but percentage of usable heat is low (2 Law of Thermodynamics, Carnot ratio) - http://homeenergypros.lbl.gov/profil...-second-law-of
    It works differently with steam boilers, looks like you have a live demo.
  1. Steam heat and pressuretrol switch
    By racerc20 in forum HVAC Heating & Cooling
    Last Post: 02-02-2010, 05:16 PM
  2. pex and steam heat
    By arturofitz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2010, 09:24 AM
  3. steam radiator valve for hot water heat
    By chickenbrown in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2009, 07:48 AM
  4. Clicking noises in steam heat pipes??
    By Katie Easton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2006, 04:57 PM
  5. Boilers, and Steam for heat
    By kerrpress@telis.org in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-04-2005, 07:04 PM
