Thread: Please help me with outdoor plumbing.
    DIY Junior Member mike932's Avatar
    Apr 2013
    CA
    Default Please help me with outdoor plumbing.
    Hi guys. My friend has a 10" x 4.5" whole house filter housing right next to her house. I want to replace it with a 20" x 4.5" housing to increase water flow. I know very little about plumbing.
    I've already bought the 20" housing, but the threads on the housing do not match the threads on the old housing cap, which means I must remove the old rust-colored cap between points B and C in my photo.
    Looking at my photo, can I just use wrenches to unscrew the pipes at points B and H?
    If so, can I connect flexible plumbing to points B and H and connect them to my new assembly? The reason I want to use flexible plumbing is so the new housing can rest on the ground to prevent putting weight on the old plumbing. The new housing cap has 1" diameter threads on the inflow and outflow.
    Is the white substance on the pipe threads teflon tape?
    Nov 2006
    Quote Originally Posted by mike932 View Post
    That is not going to increase flow. The longer housing will only decrease the amount of time between changing filter cartridges.
    No. There are unions between A & B and between D & E, and those are where all of this would begin.
    ...can I connect flexible plumbing...to my new assembly...so the new housing can rest on the ground...
    That is an extremely bad idea since that will make a nightmare of changing a cartridge.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    The old filter looks like it already has 1 x3/4 bushings in it, so if you remove them and screw them in to the new filter, it MIGHT fit back into the same place.
  1. Bringing plumbing to an outdoor shed?
    By aprofetto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2011, 06:15 AM
  2. Disconnecting outdoor plumbing?
    By CGHSW in forum Shower & bathtub Forum & Blog
    Last Post: 01-11-2010, 11:30 AM
  3. Outdoor plumbing in New England
    By sebrulotte in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2009, 07:34 AM
  4. Plumbing for Outdoor Kitchen
    By SeattleSoxFan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2009, 05:02 PM
  5. Outdoor plumbing?
    By metlc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2005, 02:53 PM
