Results 1 to 8 of 8
Thread: installed new shower body, low water pressure
    DIY Junior Member backdown00's Avatar
    Jul 2013
    USA
    Default installed new shower body, low water pressure
    Hello All,
    I recently had the below shower body installed:
    http://www.moen.com/search?search_sc...ms=Moen+3867BN
    And now the water pressure is so low its hard to even shower. There is great pressure throughout he rest of the entire house. Not sure how to fix this?
    Thank you all!
    Apr 2012
    New York, NY
    Well...it's a 2.5 gallons-per-minute showerhead. It probably isn't the pressure, per se, that's the issue, it is likely the flow restriction device contained in the showerhead. Although the EPA keeps trying to make it more and more difficult to remove these devices (which you either perceive as pernicious or glorious), most showerheads today still come with them being fairly-easily-removable. If it is not unlawful to do so where you are, I might look at the instructions and see if there isn't a section regarding "low water pressure" wherein they explain how to properly configure the showerhead where low local or well water pressure makes it not function properly with the restriction device in place...
    It could even be flow lost because of the vacuum breaker in the line. Without being there it is impossible to tell you WHERE you are losing pressure and flow.
    It's hard to know what the state of your plumbing is in the UK. While there are some people that visit from outside of the USA, problems you may have related to your infrastructure probably wouldn't even be thought of by most of us.
    WHat are you using for hot water supply? What is your actual water pressure? If you're running the hot with a pumped system, the pressure isn't the same on both the hot and cold supply lines...on US style valves, this will prevent the valve from opening fully (there's a pressure balance valve in the thing). That's the only big thing that comes to mind, but a bit of info on your supply setup may be useful.
    Plumber MichaelBukay's Avatar
    Jan 2013
    San Diego, California
    maybe they didn't flush out the sediment after they sweat the pipes. could be a clogged screen in one of the connections. or some junk ended up in the cartridge. if someone other than you installed it, they should take the time to fix it.
    The item he shows is a handheld shower unit, NOT a shower valve, so the comments about soldering or installing a valve may be irrelevant.
    Jul 2013
    USA
    Quote Originally Posted by wjcandee View Post
    Based on everything I have seen, this might be it. I'm going to attempt to fix this tomorrow by putting a hole in this white cap (flow restrictor) in the shower head so that more water is flowing through
    Jul 2013
    USA
    After removing the shower head, there is some sort of screen filter part where the shower head connects to the flexible pipe. When I removed that the pressure is crazy powerful. I assume this net is a filter of some sort, no idea why or how its blocking pressure.
  1. Replies: 2
    Last Post: 12-02-2012, 07:03 AM
  2. Installed new shower head, now no hot water
    By maldives in forum Shower & bathtub Forum & Blog
    Last Post: 10-02-2009, 06:29 AM
  3. Installed shower cartridge, now I get hardly any water flow
    By baka98 in forum Shower & bathtub Forum & Blog
    Last Post: 02-17-2009, 10:41 PM
  4. delta shower valve body - no water
    By jrburt in forum Shower & bathtub Forum & Blog
    Last Post: 05-21-2008, 04:56 PM
  5. Issue w/ water pressure on newly installed island
    By osx-addict in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2008, 09:51 AM
