Results 1 to 5 of 5
Thread: 100 year old drain line professional augering?The kind with blades to remove build-up
    DIY Senior Member CanOfWorms's Avatar
    Feb 2013
    New Jersey
    Default 100 year old drain line professional augering?The kind with blades to remove build-up
    Line currently blocked and when something up top gets flushed it backs out of basement toilet.
    I will let it sit for several hours till the water seeps out.
    I'm going to snake until I get some flow then put the hard-core sulfuric acid stuff that sizzles when you put it down the line.
    This will get me out of the woods.
    I want to call in a pro to do angio-plasti on the lines. I saw a skecth at the supply house with different augering bits.
    What is the safest cutting augering bit/ tecnique.
    I don't want to do the pressure blast since My pipes are old and run under the concrete floor the length of the basement, so I don't want to risk someone breaking a connection.
    If I had to guess the lines sit in sandy dirt with a two inch layer of hand poured concrete.
    Feb 2013
    New Jersey
    Any thoughts on the auger to permanently remove build up in the pipe?
    In the Trades joemcl's Avatar
    Mar 2013
    Pennsylvania
    If you are going for best cleaning , I would have the lines water jetted.
    Nov 2006
    Quote Originally Posted by CanOfWorms View Post
    ...then put the hard-core sulfuric acid stuff that sizzles when you put it down the line.
    Be absolutely certain to tell the plumber what you have done there so s/he does not get any ugly surprises.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    I don't like the idea of putting acid in the pipes. Rotting out the pipes with acid when you can't get at them doesn't make a lot of sense.
    I would snake first, then use something safe on the pipes like Bio-Clean to remove left over grease. Instead of burning a small groove down the bottom of the mess, it eats to goo around the entire diameter of the pipe.
  1. Remove tank insulation for increased tank capacity? Drain line carry
    By gelphledor in forum Toilet Forum discussions
    Last Post: 09-21-2012, 03:46 PM
  2. Some kind of build up on the outside of the external pipes on my hot water tank.
    By Mikie Phillips in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-20-2011, 06:22 AM
  3. sludge/build up in drain line
    By sbslider in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-01-2011, 11:21 PM
  4. Frost build on small line
    By NoAC4me in forum HVAC Heating & Cooling
    Last Post: 08-09-2009, 06:21 PM
  5. ceiling fan blades for outdoors
    By Lee Tanner in forum Electrical Forum discussion & Blog
    Last Post: 02-26-2009, 04:56 PM
