Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Tub/shower pics
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Default Tub/shower pics
    After dozens of questions to this group, I finally got this project to the point where I can post some pictures. Still not fully completed, but getting there.
    That's looking very nice.
    Jan 2013
    Vallejo, Ca.
    Thanks Terry, and thanks for the advice along the way.
    Is it necessary to fill tub with water before caulking gap between tub and bottom row of tile if tub is set in a mortar/cement bed?
    Jul 2009
    North Vancouver, BC
    Awesome work. I like how you line up the niches perfectly with your grout joints.
    Jan 2013
    Vallejo, Ca.
    Soon I will caulk with silicone around the tub between the tub and bottom row of tile. My wife asked me if I was going to fill tub with water before I caulked. I don't think it's necessary because tub is set in a bed of mortar/concrete, but figured I'd ask beforehand just to be sure. What do you say?
    __________________
    Steve
    Jul 2009
    North Vancouver, BC
    post(s) deleted by John Whipple
    Jan 2013
    Vallejo, Ca.
    You'd think that being so close to the end of the project I'd run out of questions, but here's another..............I'll be tiling the vanity top, can I use 3/4" Birch interior plywood for the top under the tile? If so, should I put a coat of paint on it first? Or maybe HydroBan?
    I have a roll of Ditra, is it necessary for a countertop?
    Birch is pretty stable, but, it is unlikely that it has waterproof/resistant glue...I'd pass on it and use some ply that does...OR, consider using a chunk of KerdiBoard...just use KerdiFix to attach it to the top of the vanity and tile away. Really easy with a top mount sink, a little tougher with an undermount.
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    DIY Member hboogz's Avatar
    Mar 2013
    New York
    Awesome work. I'm no pro, but it certainly looks good. Do you have pics of the finished counter ?
    Jan 2013
    Vallejo, Ca.
    Here's a few more of the finished projectName:  85.jpg
Size:  46.8 KBName:  92.jpg
Size:  42.9 KBName:  94.jpg
Size:  49.5 KBName:  95.jpg
    FWIW, on KerdiBoard, it is the foam that is the waterproof component...the orange surfaces are for compatibility to mortar. In fact, you can poke a hole through that, and as long as it does not penetrate all the way through to the other side, not ever worry about sealing it. Those orange surfaces can wick moisture, but that's irrelevant. As long as the edges are properly sealed with Kerdifix, and the through holes either covered with Kerdiband, golden. You're missing a lot of flexibility and speed by ignoring it as a product. You can do more with it in an hour than you could in several days of building a structure like a drop in tub deck or a counter.
    Nice looking remodel, however you ended up deciding.
  1. What Shower Setup Do I Have??? (Pics)
    By Aguyinpa81 in forum Shower & bathtub Forum & Blog
    Last Post: 02-27-2012, 05:43 AM
  2. can't find this shower valve cartridge-see pics
    By juanton in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2010, 11:46 AM
  3. Can't Remove Shower Drain -- Part of Shower Pan? (pics)
    By mbloom in forum Shower & bathtub Forum & Blog
    Last Post: 07-13-2008, 06:49 AM
  4. Pics of my Shower
    By All Thumbs in forum Shower & bathtub Forum & Blog
    Last Post: 03-19-2007, 05:39 PM
  5. Shower valve question with PICS!
    By chetwynd in forum Shower & bathtub Forum & Blog
    Last Post: 01-19-2006, 04:45 AM
