Thread: Garage Utility Sink Plumbing Question
    DIY Junior Member Nate Schwartz's Avatar
    Aug 2013
    Florida
    Default Garage Utility Sink Plumbing Question
    Hi all! I am looking to install a utility sink in my garage on a wall opposite a bathroom sink. As luck would have it a house is being built in my neighborhood that is the same model as mine so I was able to take some pictures of the in wall plumbing where I am hoping I can tie in.
    This is the garage side of the wall and shows hot and cold water and the drain pipe. To be honest I do not know what that smaller pipe in the lower right corner is. The same sink in my home does not have that particular pipe, but a seperate sink in the same bathroom does and it is connected to an Aqua-Gard Thermostatic Mixing Valve. I don't really understand why it is needed and why only on this one sink either so maybe someone can explain that to me as well.
    This is the same pipes from the bathroom side of things.
    My questions essentially is, can I tie in to these pipes for my garage utility sink? From what I have read and researched so far, tying into the hot and cold water shouldn't be an issue, but the drain/venting might be. The vent in particular confuses me since I do not see where or how it is vented at all. In the roughed in house I can see the vent stacks going up but I don't see this sink tying into it anywhere. The other sink in the same bathroom is vented with an AAV but the two sinks are on different walls so I don't see how they could be sharing that. Can anyone explain to me how I can do this if it is even possible? My though was to tie the hot, cold, and drain pipes for the utility sink and bathroom sink together and then just put an AAV in the garage to vent the utility sink. Please let me know if any of this makes sense or if I am completely off on all of it. Thanks so much!
    Nate
    That sink, unless it has an AAV in the cabinet is not, nor can it be, vented. From your pictures, I do not have a very high estimation of the "plumber" who installed it. Depending on where the water heater is, that third pipe could be a connection for a hot water circulation system.
    Aug 2013
    Florida
    HJ,
    So I decided to go ahead and open my own wall to see what was there. What I found was essentially the same as the pictures above except the drain pipe did in fact continue up which I assume is then attached to the vent stack. Is it acceptable to simply add a wye below the bathroom sink drain and drain my utility sink there?
    If you are cutting in a fitting for a sink on the vertical, it would be a santee.
  1. Yet another utility sink plumbing question
    By ChrisMDL in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2013, 06:17 PM
  2. Installing utility sink in garage -- opposite site of bathroom wall
    By Pickngrin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2011, 12:58 PM
  3. Garage Utility Sink
    By Big Mike in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2010, 03:25 PM
  4. Adding a utility sink in my Garage
    By manzo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2005, 03:59 PM
  5. How to drain Utility Sink in Garage?
    By guymenton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2005, 04:22 PM
