Results 1 to 7 of 7
Thread: Failed Soldered Joint - Best Repair Method???
    DIY Member philtrap's Avatar
    Jun 2013
    Long Island, NY
    Question Failed Soldered Joint - Best Repair Method???
    Folks,
    One of the soldered tee connections I just made on a new copper heating pipe installation failed and is dripping about 1 drop per minute. I'm going to fix it, but I was wondering if it was ok to just leave and it will fix itself???? (I've don this before with small thread leaks).
    Minerals may eventually plug the leak, but it may not last. Best to fix it. Keep in mind that with heating pipes, as things expand and contract, that leak might end up sucking in some air...probably not, but air inside of a heat pipe is not your friend.
    I would cut it out and replace it.
    I've never been lucky enough in forty years to find a self sealing solder joint.
    Only one way is right. Disassemble and redo for scratch.
    Nov 2010
    Maine
    Nothing fixes itself.
    Jun 2013
    Long Island, NY
    Thanks all. I took it apart and resoldered. It's all better and it took me less than 15 minutes.
    That's the best and most reliable solution.
  1. Soldered Pipework - Threaded or Soldered Valve
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2011, 11:14 AM
  2. Soldered Joint Faulire Rate?
    By monkeystomach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2010, 08:50 AM
  3. copper soldered joint ?
    By web_surfer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-29-2009, 05:42 AM
  4. Failed joint at shower head
    By wadswob in forum Shower & bathtub Forum & Blog
    Last Post: 07-07-2008, 07:16 AM
  5. Testing soldered sweat/PEX adaptor joint?
    By DVMSteve in forum Shower & bathtub Forum & Blog
    Last Post: 01-11-2006, 04:17 AM
