Results 1 to 8 of 8
Thread: Shopvac dead - fusible link?
    DIY Member coopns's Avatar
    Sep 2006
    Massachusetts
    Default Shopvac dead - fusible link?
    ShopVac suddenly stopped. Took it apart and after some research looks like a fusible link. Do I buy that or make one? Should those two metal ends in the picture be connected? If so, how and with what.
    I hooked on the multimeter and it made a sound/number moved when I put a piece of copper between the two end connectinos. It looks like those should be connected at the ends there ...Please advise. Go gentle now, just learning.
    Nov 2006
    Take a look at this thread...
    http://www.electro-tech-online.com/g...vac-motor.html
    It looks to me like you just need to replace that seeming "fuse" with a thermal overload protector having a value below that of the melting point of ShopVac plastic.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Sep 2006
    Massachusetts
    Where would you buy such a thing? Would they have them at the big box stores or would I have to got to a electrical supply company?
    Thanks for the link.
    Coop
    Mar 2011
    Houston, TX
    The Armature does not look to good in that motor.
    It will need to be cleaned up and the brushes should be replaced.
    Protectors open for a reason. You can buy thermal protectors online.
    http://electronics.mcmelectronics.co...thermal%20fuse
    It would be better to get the original parts from the manual if you can find them.
    Good Luck.
    Jun 2007
    North Carolina
    Throw the damn thing in the trash and buy a new one
    Mar 2011
    Houston, TX
    That may be a good idea.
    Most likely the bearings are in need of replacement also.
    There's probably a good reason why the fusible link blew: bearings, brushes, dirt, worn insulation, etc...sometimes it's not the best idea to patch it back together.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Laughed so hard tears rolled down my leg
  1. link please
    By Toolman0114 in forum Toilet Forum discussions
    Last Post: 12-13-2009, 09:11 PM
  2. 30A Fusible Disconnect Switch w/ Copper Pipe used as fuses
    By edstevn in forum Electrical Forum discussion & Blog
    Last Post: 11-06-2008, 10:30 AM
  3. Link for this site.
    By B2CHR in forum Computers and Stuff
    Last Post: 07-14-2008, 11:28 AM
  4. Plumbers Link
    By Cookie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2007, 07:09 PM
  5. link trade
    By james_bond_007 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-10-2006, 01:15 PM
