Results 1 to 5 of 5
Thread: Septic Tank Redo
    DIY Member dw85745's Avatar
    Oct 2004
    Arizona
    Default Septic Tank Redo
    Whoever installed the septic tank installed it backwards -- outlet higher inlet by about 1 inch.
    I'm planning on having a new outlet holed cored around 1 1/2 to 2 inches below the current.
    Whoever originally plumbed this used 3 inch ABS Schedule 40 both for outlet and inlet piping
    and appeared to use hydraulic cement around the pipe where it enters the tank. They also cemented
    the 3 inch pipe into the D-Box.
    I would like to upgrade the inlet DWV line from 3 inch to 4 inch but only have 2 inches of fall
    over about 45 feet and am concerned with possibly causing more problems if the inlet pipe
    doesn't get set just right as that will have an impact on outlet..
    On the outlet side the new D-Box, which I'm replacing has built in seals which take a 4 inch thin wall DWV.
    Questions:
    1) Should I upgrade to 4 inch on the inlet side or leave well enough alone.
    2) Would it be better to also keep the outlet side at 3 inch (sch40) instead of going to the thin wall pipe
    because that is what the D-Box will accept?
    This is the outlet end looking from tank to old D-Box
    'This looking at outlet tank end. New D-Box is pictured in foreground.
    Nov 2006
    Quote Originally Posted by dw85745 View Post
    Are you measuring that from the top of the tank or did you use a transit or a water level to compare one end to the other?
    I would like to upgrade the inlet DWV line from 3 inch to 4 inch but only have 2 inches of fall over about 45 feet and am concerned with possibly causing more problems...
    If that line has been working just fine, I would leave it alone.
    Would it be better to also keep the outlet side at 3 inch (sch40) instead of going to the thin wall pipe because that is what the D-Box will accept?
    The larger line could help lower the outlet just a bit, but I would not let the D-Box dictate thin-wall pipe if you want Sch40.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    Oct 2004
    Arizona
    Thanks for your input.
    I used a transit, but to confirm, I filled the tank to the inlet invert then measured down from the outlet invert to the water.
    My preference. Now I think of if -- by upgrading to 4 inch (pipe from residence is 3 inch), that will drop me 1 inch lower when the coupling is centered on the 3 inch which gives me even less fall as currently installed -- plus -- would also have to lower outlet pipe about another inch.
    Since the hole is being re-cored, it will be a function of pipe placement. I have two options.
    1) Place bottom of pipe on bottom of cored hole in tank (here pipe size doesn't matter.
    2) Use a link seal which will center the pipe. In this case 4 inch may be lower depending on where hole is cored.
    Right now leaning toward using 3 inch from tank and then upsize to 4 inch thin wall for the D-Box seal.
    Not a fan of the thin wall, but not sure whether its use (thin wall) is standard for residential septic systems?
    In AZ all the thin wall I've found is PVC.
    Can find both 3 and 4 inch (sch 40) in both ABS and PVC (ABS more common) but from what I've seen ABS tends to warp
    more (hard finding a straight piece from supplier).
    When I have the tank cored on the outlet side, I'm also leaning toward using link seals instead of directly cementing the pipe to the tank.
    Only question is whether link seals will stop root intrusion better / worse than cement???
    quote; Are you measuring that from the top of the tank or did you use a transit or a water level to compare one end to the other?
    IF the tank is level, measuring from the top of the tank down would be a precise measurement.
    Oct 2004
    Arizona
    I can't speak for other lids, but this one varies. IMHO best is just use tank itself as water level.
    ====== QUESTION ===================
    Went ahead and cored a 5 inch hole for the link seal (which uses 3 inch sch40).
    Opted for a 5 inch hole as I can insert a 4 inch thin wall directly into the hole and hydraulic cement around it.
    Why the industry is using thin wall for their lines (e.g. All D-Box seals and new tank seals just accommodate thin wall)
    is beyond me. Any time you need to dig, good chance putting a pick or shovel through this thin pipe.
    QUESTION:
    Is there a better (more preferred way) to affix pipe to the tank -- rather than directly cementing pipe to an old tank --using this thin wall pipe??????
  1. Connect septic pipe to septic tank????
    By Blueboat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2012, 10:10 AM
  2. septic tank
    By HAMLIN in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-06-2009, 05:50 AM
  3. septic tank
    By Woodenshoe in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-03-2009, 06:50 AM
  4. Septic gas belching past full p-traps/ Septic tank drainfield failing? Venting issue?
    By ryan100 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2008, 06:49 PM
  5. What not to put in your septic tank
    By Mike50 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-18-2006, 11:13 AM
