Results 1 to 8 of 8
Thread: Iron pump on hot water loop?
Hybrid View
    DIY Junior Member dwi's Avatar
    Jul 2013
    south west MO.
    Default Iron pump on hot water loop?
    Hi,
    In my maintenance job I came across a small B&G circulating pump installed on a hot water loop in a 60+ room Motel. It isn't very old, less than a year. I found the box that it came in indicating it is an iron cast not brass. What problems should I be aware of to report to the owner? I'm sure the cost difference was
    the reason this happened.
    Code requires it to be SS or bronze as I understand it. Because potable water has lots of dissolved oxygen, it will eat itself up fairly quickly, not counting the iron it adds to the water for potential stains on the sinks and showers. An iron pump is only okay in heating situations where it is a closed system - there, the oxygen gets purged fairly quickly and the water becomes somewhat inert.
    Jul 2013
    south west MO.
    Code requires it to be SS or brass as I understand it. Because potable water has lots of dissolved oxygen, it will eat itself up fairly quickly, not counting the iron it adds to the water for potential stains on the sinks and showers. An iron pump is only okay in heating situations where it is a closed system - there, the oxygen gets purged fairly quickly and the water becomes somewhat inert.
    Are there any potential health problems connected with this sort of thing? Wouldn't the rust build up in the water heaters over time?
    There aren't any "health problems" unless someone starts drinking the hot water. The pump will rust and deteriorate fairly rapidly because of the oxygen in fresh water. Cost and lack of knowledge, are the two most common reasons. the "rust" will occur ON the pump and will stay there until the pump fails.
    The rust particles could flow through the pipes and clog faucets and/or showerheads. Because it is being distributed to lots of places, the amount would be small at any one place, and it may not be noticeable. The 'proper' pump costs more, but maybe not when you consider that the iron one will need to be replaced sooner and could create some other issues along the way.
    If the particles detach from the pump, and they usually do not, they will go into the storage tank and fall to the bottom. The quantity would be very small so they would not "fill up" anything, nor would they gravitate to the faucets.
  1. Hot water Reciculating loop vs integrated loop question...which?
    By danrudy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2013, 10:43 AM
  2. Replies: 3
    Last Post: 01-03-2011, 01:29 PM
  3. Re-piping the main loop of a cast-iron radiator system
    By jmk823 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2009, 12:17 PM
  4. Hard Water Compatibility Open Loop Heat Pump
    By type@uwm.edu in forum Solar and Geothermal Water Heating Forum
    Last Post: 05-13-2008, 07:12 AM
  5. Hard Water Compatibility Open Loop Heat Pump
    By type@uwm.edu in forum Pumps and Tanks Well Forum & Blog
