Results 1 to 6 of 6
Thread: Any ideas how to get this grate open?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default Any ideas how to get this grate open?
    http://i.imgur.com/CSXWX3bh.jpg
    I want to open it so I can have the softener drain into it when it regenerates. However, it's been sitting there for 30 years and (it's gotten wet before) it seems like it's corroded/rusted/whatever. I think there is one screw on either side (flat head) but I'm pretty sure they're not going anywhere (I certainly cant get it to budge...I actually cant even get the screwdriver to fit properly).
    Any ideas what to do? I was thinking I could get a pry bar and try to pry it open.
    Feb 2011
    NW Ontario, Canada
    First thing is to clean up the slot. Second is to get some penetrating oil soaking on it. Third is to get an impact screwdriver that you hit with a hammer. I suspect it will either let loose or break off the head of the screw, either of which should liberate the cover.
    That said however, sticking a softener drain tube down it probably violates air gap requirements. You may know that and be planning to make a standpipe to put in it that you can then have a proper air gap on.
    Mar 2013
    Here
    Thanks for the ideas! Yeah, I've learned enough over at the softener section to know that I need an air gap, fear not!
    REMOVE the two screws anchoring it, (at 3 and 9 o'clock positions), then tap it with a hammer to break it free from the concrete.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    You could use a screw extractor. You can buy a set or individual extractors that come with a drill bit. You drill a hole in the striped screw and then insert the screw extractor. It has reversed spiral threads so that as you tighten it up, it will loosen the screw. Most hardware stores sell them.
    http://www.irwin.com/tools/screw-bol...es-combo-packs
    Another option might be to just drill the screw out. In your home, you may not need to screw the cover in place.
    Mar 2013
    Here
    Got it open! Surprisingly one screw came out after some work. The other didnt budge. So i used a pry bar. :P
    Thanks all!
  1. Outdoor patio sump with decorative grate
    By svierregger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2013, 01:05 PM
  2. Ceiling vent grate near water heater firestop.
    By Killer95Stang in forum Water Heater Forum, Tanks
    Last Post: 04-30-2012, 01:24 PM
  3. help please...I'm out of ideas
    By v1rtu0s1ty in forum Remodel Forum & Blog
    Last Post: 12-13-2009, 05:03 PM
  4. Open Hot
    By Jed54 in forum Electrical Forum discussion & Blog
    Last Post: 07-09-2009, 06:53 PM
  5. Need Ideas
    By skhan@solarsystemspk.com in forum Solar and Geothermal Water Heating Forum
    Last Post: 03-10-2009, 05:44 PM
