Results 1 to 2 of 2
Thread: Question about new clean out installation
Hybrid View
    DIY Junior Member roadrash's Avatar
    Jul 2013
    Denver, CO
    Default Question about new clean out installation
    A company dug in my front yard to put in 2 cleanouts, just outside the foundation wall after a sewer backup.
    2 weeks later, there was a new backup. The company came out to send a camera in.
    When he went to unscrew the PVC cap, the entire fitting began to spin. The PVC fitting is not cemented to the green PVC pipe. He said it was not supposed to be, due to heaving of the soil.
    I noticed an identical set of cleanouts nearby, that was obviously cemented together.
    Can anyone tell me if the PVC fitting (that houses the cap) is supposed to be cemented to the green pipe?
    Also, the caps are only about 1" - 2" above the soil. They are in a flower garden and eventually, plants will grow over them.
    Thanks for any input.
    Chad
    If teh cleanout has a screw in plug, which it should, then the fitting should be glued to the pipe, BUT, since it is green pipe it is SDR grade and regular fittings do NOT fit it unless they have a bushing adapter. "Heaving of the soil" was his attempt to "dazzle you with his brilliance" or maybe to "baffle you with B.S.".As long as it is above the soil, a plumber will be able to find it. Usually landscapers try to bury them 2" below the soil and then they are almost lost forever.
  1. Question regarding clean out placement in backyard.
    By Mike_D_S in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2013, 07:55 PM
  2. Raised head Clean-out plug removal Question
    By inertiacoupling in forum Drain Cleaning
    Last Post: 03-11-2013, 01:10 AM
  3. Question on dual direction clean-out installation....
    By tototalitarian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2011, 12:25 PM
  4. Question About Clean Out Caps...
    By Mozart in forum Drain Cleaning
    Last Post: 12-03-2010, 01:02 PM
  5. clean out question
    By Yersmay in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-03-2008, 11:07 AM
