Thread: drain or flush water heater?
    DIY Junior Member Zeak's Avatar
    May 2013
    Wash dc
    Default drain or flush water heater?
    Hi guys-
    Since moving into my new house 3 yrs ago I haven't done any maintenance on my gas water heater. I've read abut both flushing and draining the heater. Some have said that you only need to drain if you are moving the heater and that flushing is enough for routine cleaning. Others seem to think that draining the tank is the only way to really clean the heater. What do you recommend? I haven't had any problems and just want to do good preventive maintenance. Thanks.
    Connect a hose to the drain and open it up. That should do a pretty good job on sediment.
    May 2013
    Wash dc
    thanks! i appreciate it.
  1. Water won't flush down toilet but flows down drain fine
    By jmiller5580 in forum Toilet Forum discussions
    Last Post: 09-22-2011, 05:30 AM
  2. Hot Water Heater Flush......advice
    By chefwong in forum Water Heater Forum, Tanks
    Last Post: 10-13-2010, 02:17 PM
  3. 2-3 month dle water heater; To drain or not to drain??
    By delta_v in forum Water Heater Forum, Tanks
    Last Post: 03-24-2010, 11:19 AM
  4. Hot water heater drain
    By solutions in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-25-2008, 07:30 AM
  5. Replies: 2
    Last Post: 05-18-2006, 04:38 PM
