Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Bio-Clean, Bacteria Waste Eliminator, Bioclean
  1. #16
    Here are some more kitchen sink pictures showing grease in the line
    This is what happens over time on a kitchen sink trap arm.
    Where the 1.5" trap arm drops into the 2.0" x 1.5" x 1.5" Santee.
    This is why you use Bio-Clean on your drains.
    It's great for the kitty litter box too.
    Buy it here
  2. #17
    DIY Junior Member gsf's Avatar
    Jun 2012
    nj
    Default How to dissolve floating fats in home sewer line?
    Hello. In the past 3 months, I had 3 clogs in the home sewer line. Had it snaked twice and jetted once. Long story short, a section of the 6" clay pipe was cracked and was replace with pvc. Once the broken line was replaced, I had the line video inspected. Found that there is a back pitch in the home sewer line as it gets close to the city sewer main. But the most disturbing was the amounts of fats or grease floating in the pipe. Attach is the pic from the video cam. i tried flushing it with the hot water in hopes that it would melt but that did not work. Is there any chemicals available or recommendations that would be able to dissolve the floating fats?
    Thanks for the help.
  3. #18
    Something like Bio-Clean will get rid of the grease.
    In the city of Bellevue, they require restaurants to use either Bio-Clean or something like it for the grease problems that cooking makes.
    It does a nice job of removing grease all around the pipes. It doesn't burn holes in the pipe like some chemicals can either.
  4. #19
    Jun 2012
    nj
    Thanks Terry for the recommendation on the Bio-Clean. Will definitely look into it.
  5. #20
    DIY Junior Member calcks's Avatar
    Jan 2013
    Issaquah, WA
    Hi Terry, I have apt building (8 units) and had drain plumber try to rooter a lower unit line today. He says it's so full of grease he can't get the rooter to open it up and is planning to return Monday with high-pressure truck to try to blow the line clear. Thought I'd try Bio-Clean over the weekend, but can't find it. Do you know where in Puget Sound I can buy it and pick up Sat (1/12)?
    Thanks,
    Karen
  6. #21
    Karen,
    Thanks for the order of Bio-Clean.
    You can pick it up tonight!
    http://www.easycarts.net/ecarts/terr...html#Bio-Clean
  7. #22
    DIY Junior Member Sdunn's Avatar
    Mar 2013
    Lancaster PA
    Hairyhosebib. If your looking for a product that removes uric build up in urinals. Cantol's Aci-tech works extremely well, if you need a non acid product they also offer NonCorr.
    ACI-TECH is a multipurpose acid cleaner containing a blend of powerful acids combined with a solvent, penetrant and inhibitor to cover a wide variety of applications. ACI-TECH efficiently and economically removes rust, scale, hard water deposits, uric acid deposits, concrete, oily film, stains and discolorations from brick, stone, concrete, most metal, ceramic and quarry tiles, terrazo and china-like (urinals and toilets) surfaces.
    Noncorr APPLICATIONS
    Processing Plants: tile floors, walls, grouting, and stainless steel equipment.
    Kitchens: floors, walls, grouting, stainless steel equipment, food preparation surfaces, steam tables, fish tanks, coffee makers, blenders, and other
    appliances.
    Housekeeping: bathrooms to clean toilets, urinals, tile floors, walls, sinks faucets, tubs and showers.
    Brewery: tile floors, walls, and grouting, stainless steel tanks, equipment, pipes and valves.
    Engineering: to remove hard water scale from heating, air conditioning equipment, and humidifiers
    General Maintenance: cement sidewalks, terrazzo floors, patios, and around swimming pools.
    Rust Removal: metal surfaces, concrete, toilets, urinals
    There number is 1-800-387-9773
    Hope that helps thanks Shawn
  1. Well Bacteria fix
    By 4me2see in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-14-2011, 07:48 PM
  2. Bio-Clean, Bacteria Waste Eliminator, Bioclean
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 01-27-2009, 09:48 PM
  3. Waste line clean out - how to seal now?
    By jimfarrar in forum Plumbing Forum Discussion & Blog
    Last Post: 11-14-2008, 12:25 PM
  4. Air Eliminator
    By JOE1934 in forum HVAC Heating & Cooling
    Last Post: 09-10-2007, 03:17 PM
  5. 2 Q's New Clean-out & BioClean?
    By rippowam in forum Plumbing Forum Discussion & Blog
    Last Post: 09-27-2005, 08:38 AM
