Results 1 to 7 of 7
Thread: 2 houses on 1 submersible pump?
    DIY Junior Member Rancher's Avatar
    Jun 2010
    Fairbanks Alaska
    Default 2 houses on 1 submersible pump?
    Been trying to get this figured out: Pump is 3/4 hp new submersible. House 1 is 88 feet away and house 2 is 45 feet away from well house. Water is at 60 feet down and 20gpm. How can I supply both houses without loosing water pressure at either house? Where does the pressure switch plus check valves go? I've been thinking of those cvs valves but not sure of the instillation method. Are there any drawings of this proper installation? Thanks
    Moderator valveman's Avatar
    Mar 2006
    Since you have a “well house”, I would install a Pside-Kick in the well house. Then just tee off lines to each house. To keep from losing pressure to either house, I would run at least 1 ” pipe under ground.
    See this link;
    http://www.cyclestopvalves.com/prod_psidekick_apps.html
    Jun 2010
    Fairbanks Alaska
    Thanks I've check on that however I already have 2 pressure "bladder type" tanks plus the sidekick is sorta pricey. Just don't know for sure how the pressure switch will respond to both houses. I'm going to get a Cycle Valve tho so will place it before the sediment filter? Will I need a check valve going to each house so as not to have each "rob" all the water pressure? thanks
    Mar 2006
    You can get a Pside-Kick for $399, and it has everything you need. Pressure tanks are pricy, and the good ones are even pricier. The CSV will do a better job at reducing cycling than a half dozen tanks, so you didn’t need a very large tank. However, the CSV will work with any size tank(s).
    Large pressure tanks are just another load for the pump to keep up with. With a 40/60 pressure switch you will just have to wait for the tanks to empty down to 40, then refill to about 57 PSI before the CSV starts working and you see the strong constant pressure you will learn to enjoy. With the small tank you would have seen the strong constant pressure before you got the shower temp adjusted.
    The CSV still helps with large tanks, and it actually the best of both worlds. Ie; You have a few gallons of stored water in the tanks, the CSV still delivers constant pressure, and stops cycling which makes everything last longer. It doesn’t make enough difference to waste money on the larger tanks, but since you already have them, might as well use them.
    The CSV1A is probably the best one for your application, and they sell for around $200.
    And no other check valves needed except the one on the pump.
    Jun 2010
    Fairbanks Alaska
    Ok thanks valveman, I've ordered the new csv yesterday, canhardly wait to see this work
    Feb 2011
    NW Ontario, Canada
    With a 40/60 pressure switch you will just have to wait for the tanks to empty down to 40, then refill to about 57 PSI before the CSV starts working and you see the strong constant pressure you will learn to enjoy...
    If you can narrow the range on the switch, having it start at 50 PSI would lessen the time waiting for good pressure.
    Jun 2010
    Fairbanks Alaska
    I'm printing all this stuff, some kinda science going on here <grin>
  1. One well three houses
    By DLeppik in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-03-2013, 06:19 AM
  2. 2 houses, 2 preasure tanks, 1 pump. Not working Help
    By 48fordf-1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-22-2010, 07:01 PM
  3. System Design for 1 well with 2 Houses? Holding Tank?
    By bewing in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-12-2010, 07:34 AM
  4. 2 Houses, 2 Pressure Tanks, 1 pump, 1 controller, 1 pressure switch pro help needed!
    By betaman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-05-2008, 05:07 AM
  5. Proper distribution for two houses & irrigation
    By sanaka in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-07-2006, 09:25 PM
