Toolaholic
General Contractor Carpenter
Re plumbing a 63 Year old home . DWV Are Cast iron and galvanized. I'm in an 18" crawler changing out a Galvanized 1 1/2 " tub P trap to ABS . After P trap + santee , goes up to roof for vent. It comes down wall void rotted off at coupling 4 ft, above bath floor ! This bath is not to be re done. Go to roof to pull up remaining pipe, no dice. Coupling is below cross 2x4 above valves. Will remove roof jack ,and roof over.
run 36" of 1 1/2" ABS with AAV . This is well above flood rim. Will use No hub in crawler, so it could be serviced. Never ran into this one before !
