Results 1 to 7 of 7
Thread: DWV Layout Question
    DIY Junior Member philwgreen's Avatar
    Apr 2013
    Dallas, TX
    Default DWV Layout Question
    In the process of building a garage addition that has living space above. There is a single bathroom on the second story with a lav, toilet and shower. The bathoom is 12' long with the toilet and shower on opposite ends. The main stack will pass up through the wall next to the shower.
    Just getting ready to start my rough in and wanted to run my dmv diagram past everyone here. My main questions are:
    1. First off, does this diagram look correct or am I way off?
    2. There is a utility sink on the first floor, I know I can't vent it using the bathroom lav drain but can it connect to the lav vent in the attic? And can that vent tie back into the main stack or does it need its own roof penetration? In my drawing I have it going up through the roof.
    3. My toilet is roughly 12' from the main stack so I've added a vent. Would a 2" vent be sufficient for the toilet?
    Any help/feedback is appreciated.
    Apr 2013
    Dallas, TX
    Looked back at my drawing this evening and realized I don't think I can vent the toilet coming off the horizontal. Reworked the drawing a bit and also tied the first floor lav vent in above the second story sink.
    We're under IPC here and from what I've read there doesn't seem to be a distance limitation for the toilet vent...I may be wrong about that though. However, if I did want to vent properly - would my revised drawing be the way to do it? I didn't know if there was any danger is the toilet siphoning any of the other traps.
    Thanks again for any help in advance.Name:  bathroom_dwv_v2.jpg
    Your toilet vent is still horizontal. As long as any trap is PROPERLY vented it will not siphon.
    Apr 2013
    Dallas, TX
    Thanks hj.
    So if my other vents are correct (i.e. my drawing) , am I ok not venting the toilet?
    If I were going to vent the toilet how do I do it so it's not horizontal?
    Electrician Chris B.'s Avatar
    Feb 2013
    Toronto, Ontario
    Quote Originally Posted by philwgreen View Post
    Thanks hj.
    Use the lavatory drain as a wet vent.
    Feb 2013
    Toronto, Ontario
    You can tie the vents together once you are (some distance governed by whatever code you are under, say 6") above the flood level rim of the upstairs lav.
    Maybe the stack should be on the toilet side of the room.
    Feb 2013
    Toronto, Ontario
    Quote Originally Posted by Chris B. View Post
    Or have two, and tie them together under the garage floor.
    (This forum won't let me save edits to my posts).
  1. Plumbing Layout Question
    By RHom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-16-2013, 07:23 AM
  2. Another DWV layout question
    By FatsoPilot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2012, 01:06 PM
  3. Question about vent layout
    By ldwaard in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-07-2009, 05:59 AM
  4. Drain Layout Question
    By Justin2002 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2009, 06:35 PM
  5. toilet layout question
    By Guest in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-14-2006, 10:57 AM
