Results 1 to 3 of 3
Thread: Changing salt tank - any possible negative ramifications
    DIY Junior Member theboneman21's Avatar
    May 2013
    New Brunswick
    Default Changing salt tank - any possible negative ramifications
    I have a Culligan mark 89
    My current salt tank is about 4.5 feet high. It is in a closet in my basement. Needless o say when it is maintenance time it is a colossal pain in the neck to empty and lug
    I can get a smaller one,3 feet, for about $100 which seems reasonable to me. Will that have any negative impact ? The 3 footer will contain 3 bags of salt so 120 pounds. Each regen is set to 10 pounds so i think that is more than enough ?
    Jan 2012
    California
    The amount of salt storage vs. salt dissolved are totally different. Your salt tank needs to be large enough to hold 3-4 gallons of water above the air check in the bottom of the brine tank, the salt displaces approximately 50% of the space water will occupy. An 18" diameter round brine tank will dissolve approximately 1.6 pounds of salt per inch of water in the salt. A salt grid will allow a smaller brine tank to be used in many applications since it eliminates the displacement of water by the salt as high as the bridge goes.
    The maximum water height is determined by how high the float can be set.
    In general, even the smallest brine tank will work up to 10 pounds of regenerant. You should be just fine.
    May 2013
    New Brunswick
    Thank you sir !
  1. Install question about salt storage tank overflow
    By angboy in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-27-2014, 08:46 AM
  2. Dead frogs in salt tank!
    By Carol Brasby Clarkson in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-08-2013, 09:13 AM
  3. Changing tank to switch line on bore well tank
    By Jester in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2011, 12:47 PM
  4. salt forming around outside of brine tank
    By chris fox in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-27-2010, 08:19 PM
  5. Emptying water softener salt storage tank
    By DFMeer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2005, 07:05 PM
