Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Converting Shower Stall for Laundry Service
    DIY Junior Member CleanSC's Avatar
    Mar 2013
    Miami, FL.
    Default Converting Shower Stall for Laundry Service
    Afternoon, fellas. House is a 1971 slab on grade build in Miami FL. DWV is CI. Supplies in copper.
    I have an originally installed shower in the garage that's not needed. I'd like to stack my laundry in it instead. The shower has been demo'd down to studs and slab on grade. I have a 2" drain in the floor with a new pvc p-trap. I have 1/2" copper supplies of hot and cold.
    Do I need to do anything special here to adapt this to washer/dryer use besides simply changing the supplies to laundry hookups and raising the drain standpipe up to proper level?
    Any other suggestions for proper plumbing in this conversion?
    Thanks all!
    Jose R. - Miami, FL
    Mar 2013
    Miami, FL.
    My main concern here is the standpipe and trap. The shower trap was 2 feet below the slab underground. Can I keep it here and just extend the standpipe from there or should I move the p-trap up above the slab? If I leave it down there, the standpipe will be pretty long and I think I've read that's a no-no. Moving the p-trap up above the slab would obviously shorten the standpipe length.
    Thanks for any direction, fellas!
    Jose R. - Miami, FL
    It is not that simple. If you leave the trap there you will have an excessive drop for a standpipe. But, if you elevate the trap, you will create an "S" trap which is even worse.
    Mar 2013
    Miami, FL.
    Thanks, hj.
    So what steps need to be taken to do this properly? I have attached a drawing of what we got. I have the drain opened up back to the horizontal pipe. I can build back from there however necessary.
    Thanks again!
    Jose R. - Miami, FL
    The trap needs to be above the floor level, and vented.
    There is a vent for your existing shower, normally withing five feet. It may be in one of the side walls of the shower now. You will want to use that vent.
    If you were to use the p-trap in the ground it's current location, it would just siphon itself dry.
    804.1 All plumbing fixtures or other receptors
    receiving the discharge of indirect waste pipes shall be
    approved for the use proposed and shall be of such
    shape and capacity as to prevent splashing or flooding
    and shall be located where they are readily accessible
    for inspection and cleaning. No standpipe receptor for
    any clothes washer shall extend more than thirty (30)
    inches (762 mm), nor less than eighteen (18) inches
    (457 mm) above its trap. No trap for any clothes
    washer standpipe receptor shall be installed below the
    floor, but shall be roughed in not less than six (6)
    inches (152 mm) and not more than eighteen (18)
    inches (457 mm) above the floor.
    Mar 2013
    Miami, FL.
    Thanks, Terry.
    Yes, there is a vent going up the opposite shower wall which is over by the sink and toilet in this bathroom. When you say I want to use that vent, do I need to tap into it from another place or the existing shower vent is ok?
    How can I properly come up from the horizontal branch under the shower without creating an s-trap?
    Jose R. - Miami, FL
    Mar 2013
    Miami, FL.
    Is this an S-Trap? Would this layout work with the existing shower vent?
    Jose R. - Miami, FL
    That would not work. Where is the vent?
    The vent should be on the trap arm of the p-trap.
    Instead of a 90 to the trap arm, that should be a santee and the vent goes up through the roof from there.
    Mar 2013
    Miami, FL.
    Hey Terry... For venting I was hoping the existing shower vent would work. But it won't so see if the below diagram will work, utilizing the existing bathroom vent which I can tie into.
    Jose R. - Miami, FL
    Cut a tee into the vertical vent in the wall, (below any other tees if there are any), assuming it is a 2" riser, and connect the washer trap to that. If it si a 1 1/2" riser, then your drawing will work.
    Mar 2013
    Miami, FL.
    The vent riser is 2" CI. There is a sink not shown in the diagram that tees into this vent. There's a toilet in here, too altho I don't know where that vents. I will take a better look and see where the sink ties in. What tee do I use to tee into 2" CI?
    Thanks, hj.
    Jose R. - Miami, FL
    Mar 2013
    Miami, FL.
    Ok the vent riser comes out of the slab and has 10.5" clear up from the floor before the sink tees into it. As I understand it, I can forget the shower drain and all the previous drawings and tee into the vent riser just below the sink tee. It is 2" CI. I will then abandon the shower drain, cap it off, and bury it.
    Questions:
    1. Is capping and burying the shower drain acceptable? I'd make it a floor drain but I don't need it and I'd rather not get into keeping the trap wet.
    2. How do I tee into this CI vent riser? Cut and replace with a rubber tee? It's immobile as it's embedded in the concrete slab.
    Here's a pic. Sorry for the crudeness, the fancy autocad drawings are at only when I'm at the office. Thanks, fellas!
    Jose R. - Miami, FL
    Those are a lot of if's
    1) If you need a floor drain, the shower p-trap would work as is. It would need a trap primer.
    2) If you need a washer and a 2" sink drain is there, you can cut in below that with a cast iron tee and no-hub clamps.
    I'm assuming though, that this sink is not wet venting the shower. If it is, then the shower p-trap would not be used unless you add a vent for that.
    If you remove the p-trap in the floor, you can get a blind cap that installs with a no-hub coupling.
    A rubber tee can not be used. Those have "never" been legal, only sold at homecenters, and never installed with a plumbing permit.
    If this is IPC code, they may want 3" for the washer to dump into.
    Mar 2013
    Miami, FL.
    1) No floor drain. The shower drain would be capped and buried. Is this product okay for that?
    2) I will need to source a 2" CI santee correct? Like so? And it must be CI, nothing else easier to source?
    Thanks, fellas!
    New drawing:
    Jose R. - Miami, FL
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Still need to revent the washer stand pipe above the sink.
  1. Is shower stall ceiling lighting required in a new renovation shower?
    By GGB in forum Shower & bathtub Forum & Blog
    Last Post: 05-07-2012, 05:13 PM
  2. Bifold Shower Door For Stall Sized Shower 40.25" Wide
    By turbocruiser in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2011, 04:57 AM
  3. Convert Slab Shower Stall to Level Floor for Steam Shower Unit
    By Saitek in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2010, 02:09 PM
  4. Converting Hand-Held shower to Shower Head
    By Vatch in forum Shower & bathtub Forum & Blog
    Last Post: 06-30-2007, 08:35 PM
  5. Turning walkin shower stall into bathtub/shower combo
    By Brian_Houston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2005, 05:13 PM
