Results 1 to 2 of 2
Thread: How much gravel should I put in a 10x54 tank?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default How much gravel should I put in a 10x54 tank?
    Is 15 lbs enough? Finally (finally) getting around to installing this sucker (many thanks to dittohead!).
    Jan 2012
    California
    15 pounds is enough. Technically, you should fill the dome with gravel, the dome is .09 Cu. Ft. on a standard 10" diameter tank. This would be approximately 10-15 pounds of gravel.
  1. Gravel Bed Question
    By benzo in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-26-2012, 01:03 PM
  2. underbed gravel question
    By hobiecatter in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-10-2011, 04:47 PM
  3. Rebed- what type of gravel???
    By croghanite in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-05-2011, 08:51 AM
  4. Gravel or Garnet for the under bedding?
    By Old Fart in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-16-2011, 03:21 PM
  5. How do get thru gravel?
    By ron in sc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-05-2007, 06:26 AM
