Results 1 to 2 of 2
Thread: Wagobox to splice (2) 12/2 with ground cables
    DIY Junior Member pex006's Avatar
    Jul 2012
    Pittsburgh, Pennsylvania
    Default Wagobox to splice (2) 12/2 with ground cables
    Hi need to splice (2) 12/2 with ground cables. I have used the Wago connectors and saw this WagoBox that is designed to work with them. I was wondering if anyone could tell me if it is illegal to use here in the USA since it only has a BS EN60670-22 Compliant Lising and is not UL listed.
    It is rated for up to 41amps and 400v / 4KV
    It is 4.25 inches x 1.7 inches x 1.5 inches
    Here is a link for information
    https://www.wagobox.com/shop/junctio...ox-single.html
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    That's a weird thing you have found there. I doesn't look like something that would be compliant in the U.S.
  1. Lights Flickering - bad splice in panel?
    By mhmmofro in forum Electrical Forum discussion & Blog
    Last Post: 09-30-2012, 12:49 PM
  2. New splice fitting
    By thezster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2009, 04:59 PM
  3. Connecting a 3/0 Splice
    By JoeyC in forum Electrical Forum discussion & Blog
    Last Post: 12-31-2008, 07:36 AM
  4. Splice sprinkler cable?
    By mntentman in forum Irrigation / Sprinkler Forum
    Last Post: 08-04-2008, 06:35 AM
  5. Gas Line Splice: How to avoid an EXPLOSION!
    By pseyle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2007, 07:54 AM
