Results 1 to 9 of 9
Thread: Debris in my filter housing - what is it?
    DIY Junior Member mortal798's Avatar
    May 2011
    Pinckney, MI
    Default Debris in my filter housing - what is it?
    I have a bunch of 'stuff' showing up in my filter housing. I'm not sure what it is. I don't know if it is being pulled up out of my well, or if the inside of my pressure tank is rusting and falling apart. I will post some pictures in a minute...
    May 2011
    Pinckney, MI
    Here are 2 pics:Name:  debris 1.jpg
Size:  86.7 KBName:  debris 2.jpg
    May 2011
    Pinckney, MI
    Any ideas?
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    What kind of tank do you have?
    May 2011
    Pinckney, MI
    Well-trolName:  image.jpg
    Apr 2012
    ct
    It's possible the diaphram has ruptured and the shell is rusting from the inside out. How old is the tank?
    Does the tank feel heavy?
    If you knock on the lower 1/3 of the tank when it's empty does it sound hollow or is there a dull thud?
    Does the pump short cycle?
    If you run a hose off the tank does the water run clear?
    What is the air pressure on the snifter valve at the top of the tank when the tank is empty?
    Do you get any water out of the snifter valve when the tank is up to pressure?
    May 2011
    Pinckney, MI
    The tank is original to the house as far as I know - 1994.
    I will empty it today and find out what it sounds like, how heavy it is, as well as what the air pressure is.
    The pump does not short cycle, I replaced that 2 years ago.
    I will check the water clarity when I empty it.
    What is the snifter valve? Do you mean the Schrader valve like on a tire - for filling it with air?
    May 2011
    Pinckney, MI
    Thanks, by the way, for your help. I really appreciate it!
    DIY Junior Member BenWoj's Avatar
    Aug 2013
    Tecumseh, mi
    Glad you posted this. I have the same issue and assumed it was coming from the well. I'll have to check my tank now.
  1. filter housing for best pressure
    By Cindy Caragine in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-25-2011, 10:17 AM
  2. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2011, 02:04 PM
  3. Whole house water filter cartridge stuck in housing?
    By Trawg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2010, 12:08 PM
  4. Filter Housing Help
    By kristof in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2009, 03:07 PM
  5. Water coming up through well wiring housing
    By kcmhall in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-19-2006, 11:36 AM
