Results 1 to 2 of 2
Thread: no house water
    DIY Junior Member sj's Avatar
    Jul 2013
    durham, nc
    Default no house water
    last friday i lost water pressure in my house. what i know so far is diaphram pressure tank is empty (no water) and pressure gauge reads 30psi. square D pressure switch contacts are in closed position which i think this means the pump should be on. i have to guess that my pump is no longer working but i am looking for advice?
    Feb 2011
    NW Ontario, Canada
    If you have no water and the gauge reads 30 PSI, then most likely the gauge is bad and needs to be replaced. Obviously that won't get your water back. If the pump is not running, you need to check the electrical characteristics, i.e. voltage, current, resistance.
  1. Hot water only in new house
    By ou1954 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2013, 11:35 AM
  2. Why am I getting no water whatsoever from all of my hot water faucets in the house?
    By jennymaxgirl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-30-2011, 02:45 PM
  3. Lost all water to house, replaced everything...... still no water
    By Huntzman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2011, 10:47 AM
  4. Well Water Black sediment in my Whole house water filter (YUK}
    By JohnnyTuinals in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-30-2011, 08:20 AM
  5. House water turned off for 3 hours, house plumbing out of whack - Air in system?
    By jluksic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-14-2007, 05:43 AM
