Thread: Toto Nexus sticky flush
    DIY Junior Member David Sayed's Avatar
    Jul 2013
    Washington
    Default Toto Nexus sticky flush
    I have a recently installed Toto Nexus. The flush handle on the Nexus points straight down so that it must be pulled towards the operator to actuate. The flush now sticks at the 90-degree position but can be pushed back. I feel resistance while pushing it back. There is the usual nylon threaded assembly in the tank. Is this flush handle behavior something that others have experienced, and if so how is it fixed?
    I would check to make sure nothing is "hanging up" in the tank.
    Then you can use some Silicone spray on the handle pivot.
    Jul 2013
    Washington
    Thanks Terry. I used some silicone paste around the metal rod where it goes into the nylon assembly and it worked a treat!
  1. Sticky Mansfield 160 Flush Valves
    By wallskev in forum Toilet Forum discussions
    Last Post: 12-31-2012, 02:30 AM
  2. Toto stuck/sticky handle
    By DUANE FUESLEIN in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-05-2011, 09:24 AM
  3. Toto Nexus
    By Sanz in forum Toilet Forum discussions
    Last Post: 07-06-2010, 12:01 PM
  4. Toto Nexus
    By Cheryl2 in forum Toilet Forum discussions
    Last Post: 01-20-2010, 03:52 PM
  5. Toto Drake Ada....Sticky Porcelain bowl
    By cbp in forum Toilet Forum discussions
    Last Post: 03-16-2007, 04:47 PM
