Results 1 to 14 of 14
Thread: Can't locate replacement shower diverter
    DIY Junior Member
    Jul 2013
    California
    Default Can't locate replacement shower diverter
    Recently had a running tub in guest shower of my older home (`60's). I purchased a 3 handle rebuild kit that came with 3 valves, new seats, trim plates, sleeve covers and new knobs. Everything went in great except the diverter valve from the kit doesn't thread in and nothing at 2 local stores looks compatible (tried ace hardware & home depot). Additionally the old valve leaks a bit as water comes out of the tub spout when using the shower, and when I was taking it apart the knob was seized onto the splined end so I had to break the splined end off to remove the knob, so now I'm really stuck!
    I found a link on here to a shop in NY arpny.com that has an online catalog of valves. I believe I have ID'd the valve as an Arrowhead Brass ARR5003 but I can't seem to find anywhere online to purchase this, and the arrowhead brass website I found doesn't even list diverter valves.
    Can anyone help?
    Here's a picture of the old valve vs the one from the catalog for comparison - note the splined end I had to break off to remove the old knob.
    DIY Junior Member
    Jul 2013
    California
    the one they sell looks close but not quite the same as mine, do you think it would work?
    To me, it looks EXACTLY like a Price Pfister diverter stem. However, it comes in two versions. One with the thread where yours is, "Beaux art style, and the other with the threads just under the "flange", "contempera/verve" style. If it is, call 1-800-PFAUCET and get an address where you can send the picuture and they will be able to send the correct one.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    It looks like Price Pfister to me also, but "Beaux Art" not "Verve". "Verve" would not have the chrome plating and the threads on the bottom of the gland would be located differently. The "Beaux Art" is just over 5" tall while the "Verve" is a little over 5 1/2". The stem in your second picture looks correct to me.
    DIY Junior Member
    Jul 2013
    California
    I think the beaux art is the key, do you think this valve would work as a replacement?
    http://www.amazon.com/Lasco-S-1011-4.../dp/B000FH6FDO
    Nov 2009
    Victor, MT
    The S-1011-4 is the right one.
    Probably the correct one if you do not want to have PP send you one under warranty.
    Nov 2009
    Victor, MT
    The Price Pfister OEM# is 910-052.
    910-052 has the thread under the "flange" NOT at the end of the bonnet like his is. I don't have my parts breakdown to locate the one he needs.
    Nov 2009
    Victor, MT
    HJ, usually you are correct, but not this time. I do have a PP breakdown and I am looking at it now. 910-052 is the number.
    DIY Junior Member
    Jul 2013
    California
    wait, is that a joke? This diverter stem I'm guessing is 30-40 years old?
    Nov 2009
    Victor, MT
    I'm guessing more than 40. If the washer was chewed up you should also change the seat, Lasco X-23.
    The internet sites I visited all showed the wrong picture for the 910-052 stem and I did not have the PP parts catalog to verify it.
  1. Where to locate hand shower and elbow
    By Peter B in forum Shower & bathtub Forum & Blog
    Last Post: 03-05-2009, 06:40 PM
  2. Please recommend a quality replacement diverter spout
    By johnnycom in forum Shower & bathtub Forum & Blog
    Last Post: 10-04-2008, 05:02 PM
  3. Help replacement shower diverter is to short.
    By 4brunos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-09-2007, 10:16 AM
  4. tub spout/diverter replacement
    By copil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2007, 07:46 AM
  5. tub diverter spout replacement
    By apodos in forum Shower & bathtub Forum & Blog
    Last Post: 08-28-2005, 06:19 PM
