Thread: How should I prepare copper pipe for a quick connect fitting?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default How should I prepare copper pipe for a quick connect fitting?
    Any tips? Just make sure it's cut straight?
    I would pick up a tubing cutter for that. That gives a nice straight cut.
    Feb 2011
    NW Ontario, Canada
    Ja, a good one does. A cheap one puts threads on the pipe.
    Those fittings typically seal with o-ring(s). At least on the Sharkbite fittings, they tell you to use their reamer tool to deburr the end. You do not want the end of the pipe to nick or slice the o-ring. http://www.sharkbite.com/product/deburr-gauge-tool/ Personally, I think this is a very good idea for any of the similar tech stuff.
  1. The Quick Connect fitting on my new WellMate pressure tank leaks
    By LeBlanc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-16-2010, 10:08 AM
  2. How To Quick Clean Copper Fittings/Pipe
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-05-2009, 05:42 AM
  3. How to connect j leg to copper pipe
    By skara in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2008, 08:54 PM
  4. Quick Question - PCV or ABS to existing copper pipe?
    By EricaC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2006, 01:02 PM
  5. Do I need a flexible copper fitting where these lines connect
    By templar2b1ask1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2005, 12:11 PM
