Results 1 to 6 of 6
Thread: low flow toilet problem?
    DIY Junior Member mezzo's Avatar
    Jul 2013
    NY
    Default low flow toilet problem?
    i had a low flow toilet installed in basement apartment several years ago and we seem to get more backups than usual in the main trap. there never seems to be anything other than toilet paper blocking trap. i know my family is not using more toilet paper than usual so is it possible that the low flow toilet does not have enough pressure to push toilet paper through trap? did anyone else ever have this problem?
    The building trap?
    We don't have those in the Seattle area. Normally we worry about the trapway in the bowl, which may have been slowed down by objects that never made it through.
    If you are having problems with drain line carry, with paper hanging at it leaves the foundation of the building, then maybe something with a 3" flush valve or pressure assist.
    Jul 2013
    NY
    thanks for answering terry. i am talking about a private home and the main drain line trap where it enters and exits
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Normally there should not be a trap in the drain line after waste leaves the toilet. There should be inch fall per foot in the drain line with no sags in the pipe.
    Yakima WA
    I'd get rid of that house trap. That may or may not be the problem here, but house traps are eventually bad news.
    Jul 2013
    NY
    when i suggested getting rid of the trap the plumber told me that it prevents backups from the street and/or rodents from entering home (i live in new york).
  1. low flow problem
    By Gari22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-25-2012, 01:11 PM
  2. Toilet flow problem
    By retzman22 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2011, 12:41 PM
  3. Flow Problem mystery with rear discharge toilet
    By FishAllThe Time in forum Toilet Forum discussions
    Last Post: 12-31-2009, 08:31 AM
  4. Flow problem
    By estone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-06-2008, 08:18 AM
  5. Do I have a flow problem
    By designsoutdoors in forum Irrigation / Sprinkler Forum
    Last Post: 05-04-2008, 10:02 PM
