Results 1 to 7 of 7
Thread: Connect 2 city water supplies together
    DIY Junior Member daleclock's Avatar
    Jul 2013
    Michigan
    Post Connect 2 city water supplies together
    I have an 100 year old house that was once a duplex. There are two 3/4 inch water supply line coming into the basement at opposite ends. One is used for the lawn sprinkler system and one is used for the house supply. Can I connect the two supply lines in order to increase the water flow and pressure to the whole system? If so do I need to have some type of back flow valve?
    Default water lines
    The one for the lawn irrigation may be on a different rate, since it would not have "sewer charges" on it. Whether connecting both together would raise volume and dynamic pressure is unknown because it would depend on how the piping was installed in the house/building. If you did connect them then you would need backflow prevention devices on BOTH lines.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Sometimes there is a potable supply and a non potable supply. Some cities have reclaimed water that is used for irigation. They can not be connected together. You need to contact your city water department to find out what you can do.
    http://www.townofcary.org/Department...ter_System.htm
    Yakima WA
    Since this was once a duplex, it seems reasonable to think that possibly there are two separate water supplies to the house, but if that is true, there should be two meters. Is it possible the city has forgotten one of them? In any event, the irrigation line must have a back flow prevention device to protect the city water supply. I think you have some exploring to do to see if there is another meter buried somewhere. I see no advantage of joining the two lines. I would be concerned about these pipes being galvanized and becoming corroded. 3/4" is fairly small for both domestic water supply and irrigation, depending on size of the house and size of the irrigation system as well as the condition of the pipe. If you feel you need more water supply to the house, then you might be in line for a new supply line from one of the meters with a back flow where the irrigation splits from the domestic. I would consider a 1" line. Meter size would not have to be changed.
    Apr 2011
    NC
    I missed the part about the duplex. So forget what I said before. Sorry about that.
    quote; Some cities have reclaimed water that is used for irigation.
    BUT, I have never heard of it being used for "domestic" irrigation, usually just large areas such as parks and gold courses, and even then the piping is colored purple to identify it.
    Apr 2011
    NC
    Here is a link to a news paper story about the potable water and the reclaimed water pipes getting mixed up. The water smells like aerated waste water so I do not understand how some people drank it for so long.
    http://www.city-data.com/forum/ralei...reclaimed.html
  1. Low Water Pressure Woes! Pumping city water up a hill
    By ren451 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-02-2013, 06:46 AM
  2. Flex water supplies....rubber gasket vs. metal bullnose seal
    By jimbo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 06:20 PM
  3. Any risks to merging two 3/4" copper water supplies? (using T fitting)
    By CJ-8_Jim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-15-2010, 07:18 AM
  4. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2009, 09:58 AM
  5. Low water pressure from city
    By sredmyer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-17-2007, 06:26 AM
