Results 1 to 2 of 2
Thread: Can this window be repaired
    Default Can this window be repaired
    Just discovered rain is leaking through this window into the garage below.I have a picture of the rotted rail after I began digging and drilling out the rotted wood. I was thinking of first sealing it and then applying an epoxy filler to repair before calling a pro to replace the rail.Am concerned about the bottom weatherseal and what to do about it.Any ideas?
    thanks
    Nov 2006
    Sealing and filling rotted wood does not saound to me like a good idea. So if you know the brand of the window, I would see about getting a new sash or at least replacing that rotted piece...and then figure out what had gone wrong to make this happen in the first place.
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
  1. I repaired my exploded pump, but....
    By xyz in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-03-2013, 07:03 PM
  2. Can Oxbow washing machine valve be repaired?
    By comfun1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-30-2010, 05:47 AM
  3. How can a drain pipe in a brick wall be repaired?
    By Onlooker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2009, 05:58 PM
  4. Can this be repaired?
    By Sarge in forum Toilet Forum discussions
    Last Post: 05-05-2009, 06:02 AM
  5. Replies: 7
    Last Post: 07-19-2008, 08:48 AM
